Pinion Seal Leak, Salisbury Diff - Defender Source
Old December 7th, 2004, 06:53 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
My pinion seal just started leaking pretty profusely, and I'm about to go off on a 30 hr trip, 2 days highway and 1 day off road (NVTR). Might not have enough time to replace before I leave.
1. Anyone have an idea if a leaking pinion can empty the diff (the pinion seal is pretty high in terms of fluid level so at rest it could never drain out)?
2. Anyone have any experience with a bad pinion leak, and have an idea of the range I might expect to get between fluid check/top ups?
Doug W.
Old December 7th, 2004, 07:11 PM
Doug, I don't know much about the sals, but you may want to search on pirate 4x4 as the sals is almost (or is) the same as a D-60 and you might find what you need there.
Can you pull the rear drive shaft off the diff and check the pinion nut too see if it is loose?
Old December 7th, 2004, 07:41 PM
Doug's Avatar
Doug
Doug Walker
Thanks, Mike. I'm going to see if I can get in there.
Checked pirate -- mostly talk about running 'em dry. Doesn't sound too threatening to let it dribble. I just hate the uncertainty during this event. Did one of 'em with a screeching throw-out bearing and made it all the way, but what a distraction!! We'll see.
Doug W.
Old December 7th, 2004, 07:58 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Doug, make sure your breather isn't clogged, that might cause the leak. I've seen brand new pinion seals fail on stock D90s but don't have any experience with the Sals, sorry. Good luck at NVTR!! Kick some ass!!
John C.
Old December 8th, 2004, 08:18 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Doug,
The OEM seal on the Salsbury diff is actually a leather lipped seal. When replacing, I'd see if a competent industrial seal shop could match it to a more modern replacement...you might have to take them the pinion flange and the old seal to get dimensions. If not, remember to order the paper gasket that goes behind it when ordering the seal. When tightening the pinion nut, be careful...this diff uses a crush sleeve for pinion bearing preload. I'd make sure the vent is clear and keep it topped up. Those leather seals can be pretty horrible, but you may find that after it warms up and becomes more pliable it may leak less...or not.
As to experience, I had a 110 come through the shop a couple of years age that a local quick lube place had screwed the fill plug in so far that it fell into the diff. The truck left and drove around until the diff was mostly empty. I pulled the rear cover expecting to find destruction. I found what was left of the fill plug in the cavity between the 2 pinion bearings, all chewed up. However, the gears were completely unmarked and the bearings were fine despite the lack of lubrication and the foreign object bouncing around in the gears. A new cover and some fresh lube and the diff is still fine today, which pretty much sums up the robustness of the diff design. It also holds as LOT of oil compared to the Rover diff. Hope that helps.
Rob
Old December 8th, 2004, 08:20 PM
I had one that ran on 90% water for 2 months.
Old December 8th, 2004, 10:20 PM
Doug's Avatar
Doug
Doug Walker
Thanks, all. Ran down to a local shop today and had the seal replaced -- took 45 minutes and also replaced the nut and gear oil and put in a magnetic drain plug I've had lying around. No sense gambling -- but I do hear that Sals can run dry, like Rob says, for quite a while.
Doug W.
PS: Been snowing in the mountains around Lovelock, we're taking two sets of chains per truck -- expecting to find some sizable drifts on the shelf roads out there. We'll be running late on Saturday, prolly 5 or 6 hrs of nighttime rally ending off around 10 or 11PM. Gonna be wild!
PPS: You can still enter. www.offroadexperience.com. Come play!
Old December 8th, 2004, 10:22 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Standard Dana 60 seal from any ol' rear 60 from an American truck will work... The Sals uses a crush sleave so you will need to re torque the pinion nut to 125 ft pounds after changing it...
You won't empty the diff driving it around for a few hundred miles but while leaking you should at least check it once in a while... The same oil lubes the wheel bearings..
Keith
www.rovertracks.com
Keith
Big, Red and ... aaa Red..
Old June 2nd, 2008, 06:09 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
digging this up...
Anyone have a suggestions on a brand for a dana 60 seal?
I would like to stop my leak once an for all!
Old June 2nd, 2008, 07:30 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
National 9316
Keith
Old June 2nd, 2008, 07:33 PM
D90user's Avatar
D90user
steve
thank you much!
Old August 4th, 2008, 12:26 PM
D90user's Avatar
D90user
steve
Originally Posted by revor
...re torque the pinion nut to 125 ft pounds after changing it...
Keith
www.rovertracks.com
Is that right?? I thought it was supposed to be much looser?
Old August 5th, 2008, 10:11 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
If the crush sleeve has already been 'crushed' 125 foot pounds is about where you should go to, any more will start to crush the sleeve some more.
You can also mark the nut to the pinon with a paint marker. An old rule of thumb was on an older diff it would not hurt to take the nut the width of the marker past the mark on the pinion.
If it starts to get really tight (the pinion bearings) you end up having to re do the crush sleeve (yuk) at whick point I would just put spacer in it (pita), so be nice to the cruch sleeve.
Keith
Old August 3rd, 2016, 08:33 AM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Dead thread revived - from the road
On the road with my 110, and the salsbury is running like a river. At a GM parts dealer and they have ac/delco 26064029 - is this a match for the national 9316? Parts counter knowledge is dead...
Thanks again,
Henry
Insta: shearpin_travel
Old August 3rd, 2016, 02:29 PM
Unsure of the seal cross-reference, BUT in my experience they leak because the flange is scored/grooved and it chews up the seal. Inspect the pinion yoke after removal, and if it's scored at all use a Speedi-Sleeve before reinstalling with a new seal (for the Sals it should be the Speedi Sleeve #CR99187).
Old August 3rd, 2016, 06:52 PM
Shearpin
Henry Stinson
Jason - thanks for the note. I did find the national seal in the next town; I have my fingers crossed they also have the sleeve. If not - hopefully the new seal will get me home...
Thanks again,
Henry
Old August 3rd, 2016, 07:03 PM
A new drive yoke is not expensive.
Old August 3rd, 2016, 10:21 PM
Probably $80 or so for a yoke. Speedi is like $20 and will outlast the seal and probably the truck .
Old August 8th, 2016, 02:07 PM
Shearpin
Henry Stinson
Thanks again for the speedy replies ... Rust and leather was what was found - repaired and rolling again..
Oil Leak, is it the oil pan or rear main seal??? Grover Defender Technical Discussions 4 January 22nd, 2006 08:24 PM
Salisbury Diff guard kellymoe Misc. Chit-Chat 2 November 8th, 2005 09:09 PM
110 Salisbury Diff cover AaronOwens Wanted 2 November 8th, 2005 12:34 PM
110 rear diff protection (Salisbury diff guards) dave_lucas Vendors 13 October 25th, 2005 08:08 AM
Stock OEM Ring and Pinion plus Diff kpracer For Sale - Parts 0 July 22nd, 2004 12:47 AM
