Pinion preload w/ crush sleeve - process q's - Defender Source
Old September 5th, 2016, 09:44 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Hi folks,
Just going about replacing the crush sleeve of my rear Salisbury diff (yuk) and am wondering if I screwed up something.
When crushing a new sleeve, I was going *without* a seal in place as the fit seemed very tight to me, and since reusing bearings, would require a measurement of 8-10 inch pounds of torque to move the nut/flange once torqued properly. That's *nothing*. The gasket itself seemed like it would yield that much resistance as it was very tight when I test fit the flange in the seal off the pinion shaft.
So should I have done A) installed w/o the seal, torqued down to measure 8-10 inch points of resistance on the nut and then reinstalled the seal afterwards or B) installed the seal from the beginning and set to 8-10 inch points of torque.
When I did A, the torque value w/o flange was 10 inch pounds, and once I reinstalled the seal and tightened down to the same mark on the nut (and same rev count), I was measuring 40 inch pounds to spin the flange.
I was using these two bits of info to steer me this way:
Ring and Pinion Gear Setup (Scroll down to the Dana 60) and
(YT vid)
The vid makes me think it was B. Anyone have exierpience on this?
Thoughts? Any differential gurus out there?
Old September 5th, 2016, 11:49 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Of note, this site shows the process that I followed: http://www.pirate4x4.com/tech/billavista/Gear_Setup/ (Option A)
Old September 6th, 2016, 12:25 AM
hmm...dana 60 pinion seal shouldn't drastically alter the pinion preload. not by 4x at least.
what part number are you using for the pinion seal?
Old September 6th, 2016, 12:32 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
AEU2515R
It's the type that's got the metal surround and a rubber (or leather) inside seal. It's the style that came off of the unit, and the upgraded style ones don't fit (diameter of the seal is smaller than my diff housing)
Old September 6th, 2016, 12:38 PM
Originally Posted by TheOneTen View Post
AEU2515R
curious! i personally would go with setting the pinion preload without the seal. the purpose of pinion preload is to make sure that the pinion bearings are within a certain spec, trading off between extremes of noise and life.
The existence of the seal is merely to keep lubricant in the differential. I don't know why the dana 60 video you posted shows measuring preload with the seal in. If I had to guess, I would say that the Dana 60 pinion seal is quite different from the Sals pinion seal.
Old September 6th, 2016, 12:51 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
This is what I was thinking. I can see a few potential reasons the torque-to-rotate value went up:
1. The rubber lip is *tight* on the seal and
2. The flat metal back of the seal housing *could* be touching/pushing down on the thrust washer affecting torque as well.
LT230: What's better? Proper end-float or preload torque? TheOneTen Defender Technical Discussions 11 July 2nd, 2015 06:16 PM
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Intermediate Shaft Crush Sleeve - Different Ones? Wolf Fabrication Defender Technical Discussions 0 September 13th, 2010 05:16 PM
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
300Tdi Oil Change Process ronward Defender Technical Discussions 7 August 27th, 2006 03:59 PM
