pinion bearing destroyed - Defender Source
Old September 12th, 2014, 07:44 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
A month or 2 ago I reported my D90 refusing to budge from a stoplight, as if the brakes were engaged. Eventually got the rig moving with strange noises coming from the front axle. Vehicle got towed home. CV joints were okay. Eventually I removed the front differential from the axle and took it to a shop. The cause was a pinion bearing that destroyed itself. See pic. The thing got so hot a roller or two fused together, and you can see the heat damage in the carrier. In the process, bits of the pinion bearing also pitted the other differential bearings. Ended up being a $700 rebuild job.
Not sure how avoidable this wear and tear was. Rig had 160k miles when I bought it and I changed the axle oil. I remember hearing a whining noise from the drivetrain at highway speeds but the rig is so noisy I couldn't tell if it was normal or not.
Thinking of taking off the rear differential and hand spinning it to test it out.
Old September 12th, 2014, 07:53 PM
Sign of running for a long time low on oil. Not sure why you would rebuild it, as a used one would be cheap and you could have had a trutrac for $700 or an ARB built up for a few hundred more.
Old September 13th, 2014, 07:52 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a drop in 3rd member that I am not using if interested shoot me a pm
Legend in My Own Mind.
Video of Porsche Cayenne buried/destroyed - TOP GEAR link ssbartley1 Misc. Chit-Chat 3 March 29th, 2011 04:32 PM
Ashcroft's new Ring and Pinion!!! Fivespddisco The Vendors Loft 0 May 28th, 2010 01:47 PM
Destroyed D110's in Georgia Conflict WARNING: GRAPHIC PICTURES OF DEAD BODIES Neil McCauley Misc. Chit-Chat 37 August 23rd, 2008 11:39 PM
damaged/destroyed roll cage snuffer Wanted 10 April 20th, 2006 04:45 PM
ring & pinion krisp Wanted 2 April 23rd, 2004 12:46 PM
