Pin-out for the PRC 6913 glow plug relay? - Defender Source
Old July 9th, 2007, 05:08 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Anyone know the pin-out for the glow plug relay? My glow plug light recently quit. Of course I've checked the bulb. So, I need to do some electrical but don't know what should be hot, when. Anyone have this info handy?
Old July 9th, 2007, 05:29 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I can send you the 97 Defender Electrical library in pdf form. If that would help.
Old July 9th, 2007, 05:30 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Only if it is for a tdi.
Old July 9th, 2007, 05:36 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
It is - need an email address. You can PM me.
Old July 9th, 2007, 05:42 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Chris - I'd like to get a copy of that .pdf as well for a Tdi - Thanks
Old July 9th, 2007, 08:12 PM
Cirbo's Avatar
Cirbo
Jim C.
This is what I dug up in my notes. Let us know what the final solution ends up being, as my glowplug light is not lighting either. (not that it matters in 95 degree weather)
jC
ID:	9776   Click image for larger version
Old July 9th, 2007, 11:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Its just like shttng socks. Must be bigger socks then you all are used to.
JP
legend in my own mind
Old July 10th, 2007, 05:51 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
eh?
Must be the Kansas heat...
relay
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
Glow plug wiring differences ... Retrofit Defender Technical Discussions 44 January 16th, 2012 10:44 AM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
