Pie in the sky 90 to 110? - Page 2 - Defender Source
Old February 22nd, 2013, 08:19 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by MC22958 View Post
DC roofs are crazy money when you find one. SW tops are cheap if you want the older style, newer style is a little more expensive. Newer 110's can come with a regular axle. Salisbury axles are a little harder to source especially the disc brake ones. (of Course you can convert one over) A regular axle will fit right up to a 110 the only thing you need is the bottom bolt on perch as it is a larger diameter. You will get everything back and more if you install a new galvy chassis. (if you ever sell it)
I don't really see the need for a sals rear. Wouldn't a built 90 rear ( upgraded diff like an arb, Ashcroft, or true trac) along with a set of hd axles be just fine for almost anything?
Old February 23rd, 2013, 08:17 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On the 110 build I am doing now that is what I did, use a regular Disco axle. The driveshaft will have to be lengthened. Parts are easier to source and you can easily replace the third if you ever have any problems. The salisbury is like a Dana 60 where you have to take everything out of the back. The pumpkin on the Sals is stronger but a cap, diff guard, on a regular axle seems to be fine. Indeed the axle on the sals is larger but I do not think as strong as a HD shaft in a regular axle. The outside tubes on the sals seem to be the same dimensions as the regular axle. You can also make the 110 lower spring mount plate for the regular axle or purchase them.
Land Rover 110
Old February 23rd, 2013, 10:17 AM
http://www.juracid.co.uk/gallery/misc/Diff_Diffs.jpg
Isn't it true that the Sals can be upgrades to some mighty thick axles?
http://www.washbrook.net/Stage%203.htm
Old February 23rd, 2013, 10:41 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Newer 110s(2005+) come with a P38 rear end FYI.
You little rebel, I like you.
G4 90 and 110 SD Roof Racks SafariHP The Vendors Loft 0 October 12th, 2009 06:33 AM
Lots of various 90 and 110 parts for sale Tyler Wirken For Sale - Parts 33 September 25th, 2009 08:35 AM
Remaining 90 and 110 parts for sale Tyler Wirken For Sale - Parts 3 September 8th, 2009 10:58 AM
90 to 110 Conversion Leftovers Bits Pricing Wolf Fabrication Defender Technical Discussions 4 July 12th, 2009 10:54 AM
90 roof basket the same as 110 basket? GliderKing Defender Technical Discussions 5 June 9th, 2005 06:55 PM
