Pictures of a 50" light bar mounted to a NAS D90 - Defender Source
Old January 17th, 2016, 03:38 PM
anyone have any pictures? I would like to see how it fits.
also which mounting clamps were used?
thanks
95' D90 - daily driver..
Old January 17th, 2016, 04:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you have a roof rack? You can mount it either on a roof rack or on your roll cage. You'll need a U-cradle for the roll cage. I had mine mounted underneath my Front Runner rack.
Old January 17th, 2016, 04:09 PM
I'm going to need to mount it to the Roll bar (my Roof rack is a pair of Wolf load bars and a small Yakima basket for the front only)
Its also a Soft Top with a Hard top on it.. Right now.
What i'm trying to do is tuck it under load bar height. My VisionX lights sit above it and thus interfere with the Oztent, and anything else than hangs forward of the Roll cage bars.
If that makes sense.
Old January 17th, 2016, 04:16 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
I'm not certain, but I don't think you'll be able to squeeze a 50" bar on to a NAS cage without a weld on tab. I think you'll find that your clamps will land at the radius of the windscreen hoop where they won't work. A 40" will probably be your best option for a bolt-on solution, especially if your intention is to mount it below the roofline.
Here are two that I did so you can visualize a little better. Of course, neither are NAS cages but they should at least give you a little understanding of where things fall. The 90 is running a 51" bar on an SD cage with a light/limb riser combo tab I made, and the 110 has a 40" bar with an off the shelf Baja Designs clamp...although I had to make a spacer out of some 0.75" round stock to clear the upper roof bars on the PP cage.
-Ash
Geared Restoration Co.
352-572-3236
Old January 17th, 2016, 04:21 PM
Ash That Helps.. Looks like the 40" would work (or 2 - 20") I was looking at the single stack systems like you have pictured.
Old January 17th, 2016, 04:27 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
That's a nice looking 110 Ash!
Old January 17th, 2016, 04:34 PM
Ash's Avatar
Ash
Ash Heller
Yeah definitely go for a shorter single row if you're mounting it below the bar...on the 110 I had it set to where the bar was just baaarely visible from inside the truck, and that would have been tricker with one that was taller. I almost ran a pair of 20" bars on that truck...I think it would look pretty sweet if you pushed them towards the outside of the cage and left a gap in between.
Not sure what brands you're looking at, but if you've given any consideration to the Baja Designs line of products shoot me a PM. I can probably beat most guys out there on pricing.
-Ash
352-572-3236
Old January 17th, 2016, 05:26 PM
rovertrader's Avatar
rovertrader
Dale
I put a piece of flat stock alum across the top of the A hoop to allow fitment of anything I needed- went with two 25" dual row as it allowed fogs on each end and in the middle- and I had them from a previous build ;-)
Old January 18th, 2016, 12:40 AM
The Dro
Dro
1988 Ninety
This guy welded some tabs to his cage.
Also, I saw this clamp that should do the trick.
http://www.amazon.com/dp/B01327Y03U/..._NPhNwbDQV864A
Old January 19th, 2016, 05:33 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
51" bar attached to the cage with the same brackets that Pedro posted above and the last one has the covers on
ID:	139843   Click image for larger version
Old January 19th, 2016, 06:54 PM
Thanks Guys.. i'm going to do some savings and buy 2 - 20" Baja's single stacks- Ash i'll contact you when i'm in the ball park
front lights are after this - my fake ARB's (LED sticker brand) are bright - but its just that and the light bracket are the only nice things about them though..
Old January 20th, 2016, 08:13 AM
man those things had me fooled
90, d90, ht, mount, nas
NAS 3rd brake light bar with light Macker For Sale - Parts 4 March 4th, 2015 09:49 PM
"Stinky" or "Reddy" (named by Daughter) :: 1985 Land Rover d90 pitchrollyaw Defender & Series Truck Registry 5 July 4th, 2014 04:37 PM
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
16" BMW alloys with like new Continental tires mounted hillstrubl For Sale - Parts 0 November 19th, 2011 05:15 PM
internal "B pillar" roll bar for NAS D90 hardtop Gkase Wanted 2 January 16th, 2009 03:27 PM
