Pictures of a 200tdi boost gauge - Defender Source
Old March 27th, 2009, 08:09 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does anyone have any pics of how they fitted a boost gauge fitting to the manifold?
Old March 27th, 2009, 07:38 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
which manifold do you have? (disco or defender0
Matt Browne
Old March 27th, 2009, 09:37 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Old March 29th, 2009, 02:43 PM
Drilled and tapped the manifold for 1/8" NPT. Screw in a 1/8" NPT brass fitting. No pictures, but there is not a lot of free space to put it, so you just do it where there is room.
Old March 29th, 2009, 05:48 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I drilled into one of the intercooler pipes (near to the outlet of the turbo) and inserted the union there.
my union was brass, so it wouldn't cut a thread into the (steel) pipe that well, with with a large tap, i cut a bit of thread enough for the union to screw in, i then sealed it with panel sealer!
did the job, it's now set in solid rubber.
200tdi, boost, tdi
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 04:18 PM
Boost gauge t'd off the waste gate hose tomaco1 Defender Technical Discussions 2 July 17th, 2009 09:14 AM
200tdi VDO gauge #'s tomaco1 Defender Technical Discussions 9 March 18th, 2009 11:06 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
