Picture request: Puma door - Defender Source
Old January 16th, 2018, 08:30 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Can someone post a picture of a puma front door with the panel removed? Ideally specifically of where it bolts on, on the lower rear side
Like this
Old January 16th, 2018, 08:50 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Adam,
For you, my brother, if you do not get an answer I will pull a door card tomorrow. Let me know. Will even facetime if that will help.
KGH - “Stinky LR diesel” Defender Snob
Old January 17th, 2018, 07:08 AM
KGH's Avatar
KGH
Real Name
Did you get a picture?
Old January 17th, 2018, 07:21 AM
AdamSanta85
91' D90 200TDI
Thanks. No I didn't get the picture yet but don't go crazy.. I just got the new Puma inner panels yesterday and haven't tried test fitting them yet. What I am curious about might end of being self explanatory.
I know to fit these panels to older doors I am going to have to make some kind of bracket on the one side at minimum. I was curious of how the panel sat on that (flush with door, protruding etc)
If after I try fitting it I cannot figure it out, then I will gladly take up your offer.
Let's see what happens after this weekend.
Old January 17th, 2018, 08:20 PM
AdamSanta85
91' D90 200TDI
So I pulled some parts off. Looks like it might actually work without making a bracket, and get away with just adding a couple nutserts and drilling a hole in the new panel. Ill take a picture of what it looks like once I get the glass out and new panel hung in place with the bolts that fit.
I won't know for sure until I get the door glass out
How the heck do you get the door glass out? Remove the window tracks? Are these tracks one time use only?
I also need to find a way to get the older style window track that is attached to the glass off. I think a heat gun and some patience will do the trick.
I am starting to see why power windows aren't a popular mod. The SPAL kit would have been 10x easier and 1/4 of the price.
Old January 18th, 2018, 01:21 AM
Tarheeld
Bill
1985 110
having replaced my own glass from the roll up doors. This is what I did:
1) Remove the inner panel.
2) Remove the window winder assembly
3) The glass track is glued pretty solid onto the glass but you can remove the track off the slider.
4) Glass should slip down at an angle and clear the tabs (I bent mine a bit and hammered it back into place.
Old January 18th, 2018, 07:28 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Adam, have you searched the UK boards or spoken to any of the UK parts suppliers? This has been done a lot over there as I recall back pre-puma era.
Old January 18th, 2018, 10:13 AM
AdamSanta85
91' D90 200TDI
Thanks. 1 and 2 are done. I will get the glass track off once I get the glass out using a heat gun and some finesse.
I need to remove the screws holding the felt track to get the glass out? Or are you guys just bending that and pulling the glass out of it?
------ Follow up post added January 18th, 2018 10:14 AM ------
I haven't had much luck with the UK boards. The most helpful so far has been Zach and SafariHP.
I am close to having this sorted out. The rest of my parts will be here today that will allow me to get the doors finished. Then just waiting on a couple more parts to come to finish up the wiring.
Optimistic goal is to have the glass out, and Puma panel/regulator attached tonight. Then I just need to measure out where I need to modify the glass and attach the new tabs
Old January 19th, 2018, 10:32 AM
AdamSanta85
91' D90 200TDI
Getting there...
1. Glass removed, old style strip on bottom removed.
2. New panel attached everywhere but bottom RH side. I just need to make a spacer that will go between old bracket and new panel. Shouldn't be a big deal.
Then I need to reinsert the glass back in window and start fitting everything up so I can mark where the new style glass tabs will get attached.
I wish i had bought some new window track as my old stuff is little rotten towards the bottom where the screws go. Since these doors only have another year or two left in them I will probably just try to make it work. I would rather put the door money towards the LS swap first.
Hopefully will have the passenger side finished up today.
Old January 19th, 2018, 03:25 PM
AdamSanta85
91' D90 200TDI
Victory
Old January 19th, 2018, 03:35 PM
Cliffman
Dane Walker
1988/ 110
Originally Posted by AdamSanta85 View Post
I’m jealous!
Old January 19th, 2018, 07:53 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is this the regulator you used.
Is this what you used?
On the left side anyway
Old January 23rd, 2018, 05:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
You finish these yet?
I’d like to come take a look
Old January 23rd, 2018, 07:26 AM
AdamSanta85
91' D90 200TDI
You said you have Puma doors. What do you want to look at?
Old January 23rd, 2018, 08:12 AM
KGH's Avatar
KGH
Real Name
I cannot believe the inside of your doors are dirty. This is not like you...
Good wirk, BTW.
Old January 23rd, 2018, 08:51 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
wiring, and I have a window motor I want to see if I can use on my passenger side
Old January 23rd, 2018, 09:52 AM
AdamSanta85
91' D90 200TDI
Good wirk, BTW.
Please don't set my OCD off LOL. I convinced myself I wouldn't clean up inside the doors because they are going to be replaced at some point with Puma doors. Since that picture they did receive a good vacuuming and wipe down with some cleaner.
...And thank you. I will post finished product once they are completely done. I just ordered some of those nice foam Puma water shedder things that go behind the door panels from Zack. The 10/4 wiring I ordered two weeks ago that runs from the relays in battery box to the cabin still hasn't come. My OCD forced me to go the 4 relay route. Otherwise everything is is basically done. Everything pertaining to the doors is done. Center cubby is installed, switches are wired up as far as the battery box. I am really happy with the switch location. Kick plates modified to accept the new loom etc. I modified some black thin plastic caps to cover up the window crank holes which worked out great. I am traveling for the next few days so it will have to wait until the first weekend of February to be finished.
Old January 28th, 2018, 06:10 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Does this look right?
I’m hoping this will work with my puma doors right hand side!
ID:	350641   Click image for larger version
Old January 28th, 2018, 07:43 PM
AdamSanta85
91' D90 200TDI
That looks right
Old February 6th, 2018, 02:53 PM
ViperJames
James Forte
1991 Defender 90
I have the same exact car and i have the kit for the power windows. This thread is motivating me NOT to do the swap. Having to replace the inner panel and make brackets, etc sounds like a major production. The suppliers and other things i read on line state the older model D90s like ours will work with the kit just some minor cutting of the inner panel to make room for the motor is the main thing. I am wondering if you even tried that route or just wanted to have a nice clean inner panel as the reason for going the route you did?
door, puma
Picture Request Rockware Bumper no brush guard Coug D90 Defender Technical Discussions 2 July 14th, 2010 09:17 PM
Picture request JBfoot Defender Technical Discussions 6 May 2nd, 2008 02:56 PM
door and windows bjenk Defender Technical Discussions 7 May 9th, 2005 10:08 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
Door Sill (Carpet) Trim - D90 Wagon Kimos Defender Technical Discussions 14 October 28th, 2004 08:55 PM
