Pics of HD rear axle vs stock axle? - Defender Source
Old May 9th, 2013, 12:59 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Can someone show me a side-by-side or example of a stock defender rear axle and a HD (what I think is a Salsbury??) rear end?
Seems my truck side by side of a NAS D90 yesterday looked different. Just trying to figure out what I got (and subsequently look for spare parts for her!)
TIA
Joshman
Old May 9th, 2013, 01:05 PM
RoversNorth
RN
2012 Land Rover Defender
Rover:
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old May 9th, 2013, 01:07 PM
josh-man's Avatar
josh-man
joshua
#winning
Thanks again! The news I was hoping for...
Old May 9th, 2013, 02:38 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
And just to confuse things, 110 and 130 rears from 2002-ish onwards have gone back to a "Rover" style axle:
Not a very good picture, but the casing has a more rounded piece in the middle. Eventhough it looks the same as a D90/disco1/RR classic rear axle, the metal is a good 5 or 6mm thick, very HD and quite heavy (nothing like a salisbury casing though)
And the military "Wolf" XD version has welded on bracings (like the old series axles did... you can buy these as a kit from KAM diffs)
Both of these axles use the short nose "P38" (range rover Mk2) 4 pinion rear differential in it.
Old May 9th, 2013, 03:08 PM
josh-man's Avatar
josh-man
joshua
Oh oh I want disc brakes on my rear end!!! Cant be too tough of a conversion....
Great info!
Old May 9th, 2013, 07:00 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
You might try David at atl cruiser and see if he has any more for sale.
Old May 9th, 2013, 07:31 PM
josh-man's Avatar
josh-man
joshua
Solar, can you point me to his contact info? Thanks
Old May 9th, 2013, 07:36 PM
Josh, if you search around just a little you'll usually find things faster. atlcruiser is a member here.
Old May 10th, 2013, 02:40 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Search for "Salisbury disc conversion" or "Sals disc conversion"
-Jeff
Here's a thread I did a while back on another forum
Think it might also be posted on here somewhere too.
Old April 21st, 2015, 04:18 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
so did Salisbury come on civilian 110s at all?
Old April 21st, 2015, 04:19 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Yes, many.
1970 SIIA 88, Sold
Old April 21st, 2015, 04:38 PM
To be even more confusing....
Military 90s can have an "HD" Rover style axle. These have a 4 pinion diff and much stronger 24 spline shafts than what are found is regular Rover axles.
Old April 21st, 2015, 05:49 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
so can these be dropped on a civilian trucks? Or do have to replace all the shafts as well?
I don't know terribly much about drive trains and axles.
Old April 21st, 2015, 05:57 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You can put them on d1s if you want...
Old April 21st, 2015, 08:10 PM
seaswood
Diesel
HD rear axle
I kept the HD rear axle in my xmd-90 but this meant I also had to keep the drum brakes.
The diff I thought the front & rear were the same.
One or the other had a locker added.
Old April 21st, 2015, 08:21 PM
Man Salisbury is legit. Rover axles make me so sad even the heavy duties
Old April 21st, 2015, 09:25 PM
87 D110 (Ruby)
Salisbury ... Aka plough, aka rock breaker, aka bang bang diff, aka wtf was that?
Awesome rigged piece of kit, but jeez does it hang low...just like dogs balls
Old April 22nd, 2015, 02:13 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You can fit the 4 pin diff into a disc braked axle, and also the shafts. When I did mine I recall I had to re-tap the bolt holes for the drive flanges (it was an early RR disc axle I fitted the stuff into)
Old April 22nd, 2015, 09:36 AM
jafir's Avatar
jafir
Jafir Elkurd
Does your 110 NOT have one? I thought they were standard equipment on 110, up until the time that p38 style was put in them.
Old April 22nd, 2015, 10:08 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Correct.... even the series 3 109"'s had them.
All 110's should have them. and 130's, as you say, until the P38 type one came in (2001~2 ish)
There are two types of Salisbury rear too.... standard and HD. only the casing is "HD", stronger (yeah yeah, disc and drum brakes are two other types...)
axle
1990 Range Rover w/37" MTR's and Toy Drivetrain lwg For Sale - Vehicles 0 October 17th, 2005 03:06 PM
rear stock speaker boxs aschoent For Sale - Parts 14 September 28th, 2005 10:06 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
