Pic's needed - Recovery point location on ARB bumpers - Defender Source
Old May 13th, 2010, 11:58 AM
All,
Need some pictures of where to mount my recovery points on my ARB bumper.
I am mounting the 3 ton Shackles with backing plates from EE to either the inside (winch side) of the frame rails or immediatly out board of the frame rails. Either way i need them as close to the raisl as possible for max strength.
Some pictures would be really helpful of what others have done.
Other bull bars are not really helpful since the profile is different than the ARB's ( i know some/most don't like these bars but i have been using them for a while on various trucks and they suit my needs, plus ARB is local to me currently)
95' D90 - daily driver..
Old May 13th, 2010, 01:50 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
LMK if this pic helps.
Old May 14th, 2010, 01:03 AM
yep - that is the out board position i was looking at - however the right side overlaps the indent for hte ARB sticker and so would not sit flush with the metal.
looks like inboard is where i should place them. not much room with the EP 9.0 in there but doable i think.
Old May 15th, 2010, 12:03 AM
surf110's Avatar
surf110
Ze
130 Project
I modified my ARB and added 2 recovery points.
Old May 15th, 2010, 01:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ze - that ARB looks a lot better with the mods - what exactly did you do if you don't mind me asking? And any other pics of it? TYIA.
Old May 15th, 2010, 10:36 PM
surf110's Avatar
surf110
Ze
130 Project
I removed roller fairlead support, removed original low recovering points and cut a thin plate to cover extra holes and grinding blemishes. I only did this because I get the ARB for free. You're better off buying a new bumper.
Old May 16th, 2010, 06:35 PM
Frank84
Frank Battersby
95 D90
Looks great! I think I may do something similar with the ARB on my Classic. I don't need the roller fairlead support and I'm tired of hitting and bending the recovery loops.
'95 Soft Top
'89 Classic Tdi
Old October 19th, 2016, 01:33 PM
Holy thread revival! I want to add a pair of proper recovery points to my ARB to use with a bridal strap, and wanted to know more about this style. I know quite a few of you use this style in various brands. this on is RN.
I don't see backing plates for these, so are these meant for bumpers with reinforced holes made for them, or will these be strong enough to just drill the correct size in my bumper and install?
Mark Kellgren
KM4BOR
Old October 19th, 2016, 04:19 PM
Ray_G's Avatar
Ray_G
Ray Gerber
They pivot right? Like the old SG swiveling recovery points if I recall?
I'd go backing plate just for insurance.
Old October 19th, 2016, 04:39 PM
Ray_G's Avatar
Ray_G
Ray Gerber
These are different. The SG were actually swivel hoist rings. The looked cool, but i dont think any of the manufactures would want to see them used for recovery.
-Jeff
I'd like to see more specs on the RN item-are you commenting on the SG hoist rings not being used for recovery, or these. I'm a bit skeptical of both truth be told.
Old October 19th, 2016, 05:40 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Are those swivels test rated? nothing like a 10 pound hunk of metal flying at ya
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 19th, 2016, 07:33 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Equipe used the same swivels. As long as your mounting thickness is the same as the shoulder to the snap ring, you don't need a backing plate. Looks like 1/4" or 3/8".
The ARB bumper is thinner, say 1/8" or 3/16", so you'll want to add a backing plate/ washer to make up the difference.
Semper Fi!
Old October 19th, 2016, 08:34 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
-Jeff
I think that's a stretch... I have used my SG swivel rings several times for both static and dynamic recovery, as well as seen many other SG owners doing the same. It would take an amazing amount of force to see a failure.
Old October 20th, 2016, 06:47 AM
Ray_G's Avatar
Ray_G
Ray Gerber
My swivels are rated at 5K static. Not sure on the dynamic as they aren't intended for it. Thats why i like the RN design better. On top of that I think Ray and I actually agree on somthing... -Jeff
Come on, as long as we aren't taking specific elements of politics that isn't that odd!
Old October 20th, 2016, 08:35 AM
I have used mine a few times, but only for minor needs. Never felt like they were meant for serious recovery.
arb bumper, bumper, cover
ARB Problem : HELP needed Jay Defender Technical Discussions 5 January 15th, 2006 06:09 PM
Info needed on Arb air locker. rustydefender Defender Technical Discussions 5 January 9th, 2005 03:46 PM
ARB Recovery Point TurkD90 Defender Technical Discussions 2 December 3rd, 2004 10:54 PM
Rear recovery point souza Defender Technical Discussions 33 September 22nd, 2004 11:41 AM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
