Picking up a 4.6...refurb notions? - Defender Source
Old August 17th, 2011, 11:02 AM
I have a line on a 4.6. It will likely need a going over and I am soliciting input regarding cams, head porting and valve replacement with oversize. I'll probably run it with a Megasquirt since I have a couple of 'em laying around. No diz.
Has anyone put a turbocharger or two on one of these? Looking for about 300 hp, but not with nitrous.
------ Follow up post added August 17th, 2011 11:13 AM ------
Found this:
http://baileyperformance.co.uk/?p=125
Old August 17th, 2011, 11:23 AM
where is this going?
Old August 17th, 2011, 12:39 PM
The loob eventually. The 4.2, while still in pretty good shape, did show scoring in number 8 when I had the heads off. I figure to take my time getting this 4.6 built and maybe in a year or so swap it in. Meanwhile I need to get my money's worth out of the new head bolts and gaskets.
Wanna be able to tow at more than 56 mph, the top speed I am ever able to get with the present lump. And hills, forget it.
Old August 17th, 2011, 02:12 PM
Probably wont like boost but maybe it'll work? Call Mark at D&D I'm sure he hasa recipe for one it might involve a 300 crank and SBC rods. Keep us posted.
Old August 17th, 2011, 08:44 PM
I dunno the bottom end should be OK if its kept under 10 lbs of boost. I tend toward turbochargers over roots type superchargers for the noise factor and that they seem easier to plumb in than bolting on a roots blower. You can put the intercooler anywhere. I guess that goes for the turbo too. A t3 should do the trick
Be cool to have that under the bonnet.
A fatter cam like that Crower 50230 or 232 cut should do nicely
Old August 18th, 2011, 10:09 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
There is going to be more work than you can think of, to make a turbo work with this motor. Any motor with reliability, heat, and lubrication issues is not a good candidate for forced induction. Even keeping boost at 10lbs or below, add a lot of heat, and stress on every component, to any motor not designed, and up graded to be turbocharged. The whole bottom end is going to be reworked, if you want it to last for a reasonable time. A forged cross drilled polished crank for starters, Custom rods would be best, and at a minimum, the stock rods would need to be shot peened, with up graded hardware to hold them together. Stock pistons wont last at all, and will need to address the ring set up for a compressed motor. While the cam choice would be good for a NA motor, a profile for a turbo motor are very different. Stock head gaskets will be replaced a lot faster than normal, and having the block, and head o-ringed would be the only way to go. Then the fuel injection will need remapping will take a lot of work to make sure that everything is balanced with air/fuel mixture, other wise you open yourself up for motor failure. The list goes on, and on, and on. Balancing and blue printing the motor, with the right cam profile, along with increased breathing capability, would improve the performance and drive ability by a sizable margin over stock. Not only would this set up be cheaper, but also will improve reliability as well. The big gain will come from work on intake/exhaust by matching ports on the intake, and exhaust, and then have them extrude honed to smooth the passages, and open them up for increased air flow. This and up sizing the valves can bring you to a whole new level of performance, when done correctly. Then with some tuning of the Mega Squirt, you can then take advantage of the improvements in breathing to find a happy medium for your driving style, and needs. Just my opinion of course.
Greg
Old August 18th, 2011, 10:30 PM
Thanks for typing that. AMEN
The Official 4.6 Conversion Thread Jon_Winningham Defender Technical Discussions 36 October 27th, 2010 04:36 PM
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
1998 4.6 HSE Range Rover $7500 roverover For Sale - Vehicles 0 August 18th, 2005 10:26 AM
four 4.6 18 in hurricane wheels mpheff For Sale - Parts 0 March 25th, 2005 03:39 PM
