Pic of the Box to turn off the "service engine light" - Defender Source
Old September 13th, 2011, 10:21 PM
My service engine light is on and i need to turn it off.
does anyone have a picture of good description of the box i need to push in the pin into to turn it off.
this is the reminder for service the Cat's i believe.
No codes on my read out from the ECU.
95' D90 - daily driver..
Old September 14th, 2011, 12:21 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
just pull the bulb out...why bother.
Old September 14th, 2011, 05:39 AM
maleger
Marc-Andre Leger
It is a brown relay behind the gauges / instruments panel. I just removed the relay. As someone put it in another thread on this subject, I don't need a light to tell me when to service my D90...
Old September 14th, 2011, 10:23 PM
just to be helpful for anyone else.
the way you do this is
1) remove gauge panel (4 screws)
2) locate the brown relay labeled "emmisions control reminder" or something to that effect it is large and the only brown one on the left side of the internals of the dash
3) in the middle of the sticker on the top there is a hole that you need to insert a pick into and trip the relay (or kill it that remains to be seen)
4) test by turning on ignition and see the light go out
5) reassemble the dash (4 screws)
Old September 15th, 2011, 09:29 AM
GYM's Avatar
GYM
Gary
97 SW
Can anyone chime in if that is the same process for a '97?
Old September 15th, 2011, 09:31 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
In a 97 it is down by the fuse box (not behind the dash). If you have small hands you might be able to get it out without taking the console out, but we end up taking the console out to get to it.
Email:
Old September 15th, 2011, 10:34 AM
GYM's Avatar
GYM
Gary
97 SW
Great. Thanks, Mike.
Old December 17th, 2011, 06:57 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Just for anyone's reference on my '97 I found it's mounted to the back of the fuse box panel underneath the dashboard and A/C unit, so you need to unscrew the fuse box panel to get to it. I don't see how anyone could get to it without removing the console yet alone the fuse box panel. As you can see in the photo of the brown relay there seems to be actually two holes, the one on/under the LR sticker is not the one that leads to the reset button. I found, after removing and disassembling the Emission Maintenance Reminder box, that the other hole you can see in the photo just to the left of the LR logo is the one that goes to the reset button. Of course resetting it is easy as you just need to poke a small screwdriver or something of the like through the hole in order to press some sort of reset button, I found that on the first hole I tried, my screwdriver went quite a ways in which didn't seem right. With the correct hole, the reset button, or whatever it is, is not far into the relay box itself so you'll know if you hit the right one or not. The pics I believe really help explain. So that's how you reset the light in a '97, it's a bit more complicated than it sounds with lifting the console out of the way and unscrewing the fuse panel; also a bit of a PITA for a light that just comes on after 80,000mi so hopefully the local dealer can make a few hundred or more bucks! It was funny to me that they make the Service Engine Light come on after a certain amount of time like this, as my engine is relatively new!
ID:	44969   Click image for larger version
Old December 20th, 2011, 08:24 PM
JKC
1997 D-90
Thank you for the detailed info on the 1997- pictures are great. I have been trying to find that thing for a while now. What a pain in the ass to get to - guess it will have to wait until I have another reason to take all that apart.
Old December 21st, 2011, 02:16 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
On my 97, I just took the relay completely out. Goofy little thing if you ask me.
Old February 25th, 2012, 02:56 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Doing this reset right now...Thanks for the detailed write up and pics, what a help!!
Old February 25th, 2012, 07:59 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Agreed!
Old February 25th, 2012, 09:46 PM
Ill be around on Monday if you need some help with it, its a little brown box you can reset it with a paper clip
Old February 25th, 2014, 10:55 AM
RickM
Rick Mabus
95 D-90 ST
I just got into this myself, and after jacking with the relay box for an eternity, I wound up just pulling the light. As old as my truck is and as brittle as my dash is, I should have dissabled the light first anyway.
Old September 22nd, 2014, 02:16 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
So for a 97 the brown box is below/behind the fuses. And for a NAS 95 it's behind the 'idiot lights'??
And is the service engine light the same as the CEL?
Mine came on after part of my exhaust cracked off just after the header and before the O2 and cat.
Will this brown box reset button do the trick?
Old September 22nd, 2014, 06:53 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Good job. You won't pass inspection here in Connecticut if your check engine, service engine lights don't come on then turn off during engine startup.
Old September 22nd, 2014, 07:14 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I just do the service. Too much trouble to avoid it...
Old September 22nd, 2014, 01:16 PM
petminded's Avatar
petminded
David
Yup, same here in California.
engine, ht, service
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
