PIAA 90 PRO XT (top) install questions... - Defender Source
Old June 16th, 2004, 10:30 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Fellas'... I got a couple of questions regarding installing a pair of lights ABOVE the front windshield... I will be installing them on Friday, so I'm trying to plan this out...
First, for those who have installed lights on the exterior roll-cage around the front windshield, WHERE & HOW did you route the wires ??? I'm having some difficulty thinking of how to do this... (I've got the dual OPTIMA setup with the AudioPipe Battery Terminals so I need to route the wires directly to the battery... <stole that from ExpeditionExchange.com>)
Second, has anyone installed lights on a factory safari roof rack in front ??? (not the other one's... the real one LRNA90FSRR ) I'm thinking that might look cool as well.
As always, any help is appreciated.
'Tanks
Nicholas
Old June 18th, 2004, 09:48 AM
Hey Just saw your post here are some threads on the subject.
http://www.defendersource.com/discus...s/16/1020.html
http://www.defendersource.com/discus...s/16/1226.html
http://www.defendersource.com/discus...s/16/2175.html
Old June 23rd, 2004, 10:33 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Fella's...
Got these lights in today... sweet...
only now I don't know how the hell I'm going to mount them. The 'width' between bolts is much larger than the 'roll-bar' light tabs, I'd say from looking at them in the dark they're about 1/3 inch off on each side.
Not worried, just wondering if I could get a plate and just drill 2 holes...
Anyone have experience in mounting tabs to 'existing' tabs on the lightbar part of the external roll cage and mounting lights... ?
Nicholas
Old June 23rd, 2004, 11:58 PM
Hey Nicholas, You could buy a some 1/4" thick by 2" wide steal (they sell it at Home Depot) and run it between 2 of the light tabs on the rollbar so that it bolts to 2 of the tabs. Then drill 2 hole whereever you want in the steal for the lights themselfs. Clear as mud? be sure to paint it black when done to match the cage, you can also make the steal longer then the distance between the 2 mounting holes and mount the lights on the part that hangs out so the lights are farther appart.
Old June 24th, 2004, 11:07 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Mike,
Great answer. I was thinking of purchasing some kind of steel like that but just to put over 'one' of the tabs... somehow it didn't occur to me to run the piece of steel to 'each' of the tabs.
Excellent. Thank you Sir !
Nicholas Orros
Old June 24th, 2004, 02:29 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
I know everyone seems to install the Hella-style lights above their 90's...and they look cool/OEM...but, with all the new HID light technology now, has anyone seen a neat install with those compact HID-type lights on a D-90?
I'm convinced that they have to offer advantages...especially since the 90 is shaped like a brick already, and those 4 hubcap-sized lights can't help the situation...
Old June 24th, 2004, 03:00 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Nicholas, you might want to make that bar out of angle iron or 'L' shaped steel. I have a bar and found that the light patterns vibrated annoyingly. Had to jam a piece of rubber in there to stop the shimmies!
Old June 24th, 2004, 06:03 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Done.
Not bad... a lot of measuring but all came out well.
Purchased 1" x 1/4" of flat aluminum and cut them with a hacksaw, drilled holes in it, filed the ends a little, installed, wired ... and came out pretty good. I only wish they both turned on at the same time, it seems that you can only turn either the ion crystal fog lights or the driving lamps... Maybe it does, who knows...
Have pics if anyone's interested.
Nicholas Orros
Old June 24th, 2004, 07:43 PM
howellm70
Michael Howell
Nic, can you post a few pics...I'd love to see how it turned out. Thanks.
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old June 24th, 2004, 08:38 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
no problem.
Nicholas
ID:	883   Click image for larger version
Old June 24th, 2004, 10:11 PM
Thumbs up
Nicholas Orros
Sounds exactly how I would do it! Looks Good! And with the aluminum you don't have to worry about rust!
Old June 24th, 2004, 10:34 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Thanks.
I just took a short hour cruise through some windy 35-55 mph roads and got to test them out. The fogs are just the right brightness for me and the driving lamps are a little too bright, but haven't used them in the woods or tested them in any off-road purpose yet.
I attached a pic from the front.
Nicholas
Old June 24th, 2004, 10:37 PM
looks good.
Old June 25th, 2004, 01:38 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
That is my exact rig, and your install looks GREAT. I dig it. Can you post any pics from closer to show me how you set it up? I get the idea, but if you have a pic from above or the side...
I really like that. Way better than the Hellas, I think...and better lighting, I'd assume.
Old June 25th, 2004, 02:41 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Luckily I purchased about 4ft of the aluminum because after the first cut I noticed that I had to 'bypass' the next nearest light tab from the end closest to the outside, because it was at a different 'level' than the next.
You'll see in the pics.
So, the aluminum pieces were about a foot or so in length.
Sturdy though, I don't think I've have a lot of bouncing issues.
Nicholas
ID:	919   Click image for larger version
Old June 28th, 2004, 11:19 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
How are the wires from the lights typically plumbed? I don't see holes in the rollcage (beneath the mounting tabs) to drop the wires through...but that seems to be the most sanitary way to do it, no?
Old June 29th, 2004, 06:13 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Black zip ties down the cage. Is one way.
Jimmy Buffett
Old June 30th, 2004, 10:51 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Torrence,
Just saw your post.
I agree with Tyler, cheap black zip ties are the best. I think I paid $1.18 for 8 plus the lights usually come with some...
The PIAA lights I put on had a soft white plastic sheathing (tubing) over the wires themselves that said 'PIAA' on it, so it looks pretty cool. You could drill through the roll bar but then you'll open the inside of the roll bar tubing up to the outside elements... not to mention 'what if' you had to take the lights down ?
Pain in the ass!
Anyway, these lights rule.
I'm thinking of getting another set and install them between the others. I love the look.
Just my .01 CENT.
Nicholas
Old June 30th, 2004, 12:53 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Yes, they look great. They're on my short list now, definitely. Great install.
Oh, and where to the wires enter the vehicle, incidentally?
Old June 30th, 2004, 02:12 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Torrence,
Thanks & Great Question !
After ruining 3 sets of battery cable for my winch because I had it running UNDER the vehicle like someone told me to (melted 2 cheesy thin cables <cuz I didn't know you were supposed to use THICK cable> and one set of 0Gauge 2AWG wires) I ended up drilling a hole in the 'kick panel' and running them OVER the drivers side wheel well where they were CLEAR of any HEAT.
SO... I ran the light wires right at the corner/back of the hood and right next to the winch power cable through cabin and into the battery compartment... (where I had to drill another hole).
I hated drilling so many holes but it works and is clear of any heat. (thats the killer!)
And I did the dual battery setup that I stole from ExpeditionExchange.com with the AUDIOPIPE batter terminals (those things are great) so the install after the lights were mounted was CAKE.
Nicholas
1997 Defender 90 Soft Top w/ 36K miles Willh For Sale - Vehicles 7 January 21st, 2012 11:43 PM
1997 Defender 90 Soft Top D901619 For Sale - Vehicles 9 April 5th, 2010 09:58 PM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
94' Defender 90 Hard Top RX6RCROL For Sale - Parts 4 March 11th, 2004 08:54 PM
