Photos of the various LED lights on a truck - Defender Source
Old June 30th, 2016, 06:53 PM
50thd90
50th
1998 50th D90
Trying to get an idea of the look I'd like to go with to replace the current lights on a white truck, anyone have some photos of their LED setup to help visualize the end result? Thanks guys.
Here's the current setup
Name:	Photo 6-17-16, 12 16 07 PM.jpg
Old June 30th, 2016, 08:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old July 2nd, 2016, 03:29 PM
50thd90
50th
1998 50th D90
Thanks Paul, is this the best price online for delivery to the US for the WIPAC 73mm LEDs?
Standard Size 73mm LED Lamp Kit - Coloured Lamps - Paddock Spares
Old July 2nd, 2016, 05:44 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Looks like the same kit I used. I got mine from Brian at Defenders NorthWest. You might check in there.
FWIW, although installing them is easy peasy, you might have to add resistors to combat the dreaded 'cross-flash'.
Old July 2nd, 2016, 06:09 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Brian currently has them in stock I know. I just bought a set from him Thursday.
Old July 3rd, 2016, 09:54 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
There is also the option of led retrofits for the oe lamps. Just look for good ones....lots of crap out there. I like mine from superbrightleds.com
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 3rd, 2016, 10:36 AM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
I have a spare set of LED lamps that ended up in the part stash that I likely won't be using, and could probably pass them on for a good deal.
Let me dig them out, check the kit completeness, and post up a photo or two. I'll also post a couple of photos of the LED set that I did put on my 130 F&R.
Murph
EDITED AFTER VISITING THE STASH/ADDING PHOTOS:
What I have as spare to my needs may not be what you're looking for, but photos are attached anyway, as are a few of my truck with what I do think you want.
There spare ones I can sell are not 75mm (Series/early & ROW Defender size), but 95mm ones, the size as installed on 95 & 97 NAS D90s. The kit parts are made by Wipac, and were as packaged, labeled and sold by Rovers North. I originally intended to put them on my truck, but decided to stay with the standard smaller size. The set I have is all new/non-installed in box, and includes four new plinths, an LED load resistor (you'll want to use one of these), four amber lamps and one red three-conductor (taillight/brakes) one. I used the other two lamps (white/red) I had for my rear fog and reverse lights. You'll need to track down the missing two via RN (Zack) or other D90-Source friendly sales cat.
If you can't use them, I'll likely put them up for sale later when I list some other parts. Let me know if you can use them, and we can work it out.
The other photos are of my truck with a Wipac 75mm set F&R. They're a big improvement over the stock bulbs. I also installed the little plastic "Bolt On Bits" light guards as shown in the photos as I thought they looked cool.
Murph
ID:	152955   Click image for larger version
ID:	152957   Click image for larger version
ID:	152960   Click image for larger version
ID:	152962   Click image for larger version
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'04 G4 Disco II
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old July 3rd, 2016, 02:25 PM
50thd90
50th
1998 50th D90
Thanks Murph, I do need the 73mm ROW lamps though. What do the retrofit LED bulbs look like when installed? Any before and after pics?
Old July 3rd, 2016, 11:06 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
The retrofit 'bulbs' don't look too much different from incandescent except within maybe 30-40 ft you can see multiple points of light through the lenses as opposed to the one filament. I notice it because I know they are there, not sure if anyone else would. I will try to take a pic, not sure how well it will show though.
I used the 45 led 1157's from superbright in my90 and Series tail/stop lamps.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 4th, 2016, 05:29 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I just received the full 73mm led marker kit with side repeaters from bolt on bits on eBay. They look of good quality. Ill post installed pics a soon as my truck lands.
Old August 2nd, 2016, 12:34 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Wayne,
How long have you had your LED's bulbs for the tail/brake light?
I was thinking of doing the same, though concern the taillights (since they stay on for hours on end) could/would burn out. I've had LED's (license plate light) that got so hot it burned the LED chip. Thanks!
Old August 2nd, 2016, 07:54 AM
FlyersFan76
1987 110 Convertible
edit: Delete
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old August 2nd, 2016, 10:24 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Originally Posted by lithium1330 View Post
Wayne,
Hi, I've had the led's for ~5 years on various cars, none of which are daily drivers. I have not had any problems with the ones I used, haven't seen any degradation in output and they do not seem to run excessively hot.
After a bit of trial and error, I now use these 1157's exclusively, however they now appear to be end of life'd https://www.superbrightleds.com/more.../Photos&Videos Darn...
Here is a pic of my 90 w/ them in:
Name:	LR 90 tail stop led.jpg
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
ht, lights
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 04:25 PM
LED fog lamps work lights fog lights Ben01 For Sale - Parts 2 April 20th, 2015 09:42 AM
Truck-Lite LED tail lights Hache Defender Technical Discussions 10 August 31st, 2014 11:48 PM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 04:34 AM
Trek Challenge Truck Photos- 2003 Truck aosias Misc. Chit-Chat 6 April 26th, 2010 05:23 AM
