Phillips Driver for Door Hinges - Defender Source
Old November 24th, 2013, 08:41 PM
Videoguy
Ron
1997 Defender 90 SW
I can not locate a Phillips head driver bigger than a #3. Can anyone provide a link to a larger one. I am replacing all my hinge screws with SS. Thanks
Old November 24th, 2013, 08:47 PM
Harbor freight? I got one to use on my SW a few years back...
Old November 24th, 2013, 08:52 PM
I think it should be Pozidriv not Phillips.
Old November 24th, 2013, 08:59 PM
jafir's Avatar
jafir
Jafir Elkurd
Yep. Easy way to tell is the X stamped into the screw head, between the slots. Another common screw (not on rovers, but you'll see it other places) are the Japanese JIS standard. They have a single dot between the slots in one corner.
Old November 24th, 2013, 09:09 PM
I had this problem during my rebuild.
The problem is not whether the bit is Pozi or not. The problem is the size of the bit. There are two places where this massive phillips head is used - the door hinges and the hinges for the windscreen. Pozi just changes the engagement angles and adds some additional teeth, but it is irrelevant for the task at hand. Believe me - I tried removing the windscreen hinge screws with a #3 and a #3 Pozi and I literally bent and stripped 3 bits. I then put the correct #4 bit in my impact driver and removed the screws in seconds.
The largest size every hardware store sells is a #3 Phillips.
You will need to find a #4 Phillips Bit online.
To give you an idea:
http://omegatec.com/440-4-ACR4-RX-Ap...FWTxOgodJmgAKQ
Old November 24th, 2013, 09:18 PM
Videoguy
Ron
1997 Defender 90 SW
OK, I found a Phillips #4. It is supposed to be in stock at my local Sears. With the Omega link, you have to buy a bunch.
Old November 24th, 2013, 10:21 PM
When you strip out the screw with a Phillips bit, you can remove it with a Pozi-Drive bit.
Old November 24th, 2013, 10:42 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I used the craftsman impact driver and it came with #2,3 and 4 driver sheared screws off with it and never once slipped in the head of the screw..
$25ish at sears as I recall.
Ryan
84 110SW County LHD
07 L322 Vogue
Old November 24th, 2013, 11:00 PM
Impact driver. I broke a bit with it. Then I came up with the idea of the bit in my half inch impact gun and that worked. Top comes out easy, bottom was a nightmare.
Old November 24th, 2013, 11:59 PM
Videoguy
Ron
1997 Defender 90 SW
I noticed that the bottom set is rusty looking. Not looking forward to that. How did you get the sheared screws out?
Old November 25th, 2013, 12:07 AM
You can bust the captive nut and remove it. If the captive nuts are to be reused, run a tap through them, use tones of anti-sieze and then spray it all with waxoyl.
Old November 25th, 2013, 03:07 PM
Videoguy
Ron
1997 Defender 90 SW
Picked up a 3\8 drive #4 at Sears. On sale at $3 and change.
Old November 25th, 2013, 03:26 PM
If the screws are really stuck, it is very simple to drill the head off. It is quick and easy.
door
Which Phillips driver for windscreen hinge bolt? sonoronos Defender Technical Discussions 1 December 18th, 2012 02:20 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
D90 - Daily Driver - Yes, No or Maybe? uzj100 Misc. Chit-Chat 31 July 26th, 2005 05:43 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Driver side mirror jracenstein Defender Technical Discussions 3 October 22nd, 2004 10:00 PM
