Pertronix ignition upgrade - Defender Source
Old May 31st, 2012, 01:21 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
A few years ago I was having problems with my points and condensor on my '73 Series III so I replaced it with a Pertronix electronic ignition system and have been very happy with the results. I am looking to do the same with my 3.5L V8 on my 110 and have noticed they have a complete distributor with the electronic ignition system already included.
http://www.pertronix.com/prod/new/details.aspx?ID=136
I have never replaced a distributor before. My question is if I go with this route (instead of just buying the electronic system to go in my original distributor), will I have to reprime the oil pump? I vaguely remember reading about repriming the oil pump when you take the distributor out. Any pointers will greatly be appreciated. Thanks in advance.
MUDSUX
Old June 2nd, 2012, 01:08 PM
discodaze
ian tydeman
1969 Rover Hybrid SWB,
Do you have a part number and price for that as well? Thinking about doing the same on a stage one v8
1992 Defender 110
1983 stage one v8 109
1995 disco
1969 88 hybrid
1967 88 work in progress
1957 Series 1 swb in boxes
Small addiction
Old June 2nd, 2012, 01:46 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Can't see why you need to reprime the pump, it's just driven off the bottom of the dizzy & your not draining it of oil. Would only need to do that if you'd had it out for a service/repair, then it'd be dry.
Old June 3rd, 2012, 10:04 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks! Now to do this and not mess up the timing
MUDSUX
Old June 4th, 2012, 03:03 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
So can anyone point me in the right direction to correctly change out the distributor and not mess up my timing? I am researching the net but have not come up with a step-by-step walkthrough for the Rover 3.5 V8. I know it's out there somewhere. I can't imagine it being that hard but "measure twice, cut once" I keep telling myself with this restoration. Thanks again in advance!
MUDSUX
Old August 6th, 2012, 10:57 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
Hey Forrest,
If you donít have the workshop manual for the early trucks, itís worth picking up.
http://www.amazon.com/Rover-Defend-O...orkshop+manual
It has instructions for changing out the distributor, as well as tune up information. I can post the steps as listed in the manual if you donít have it.
Anyway, it looks like I might be going this route as well. The original points ignition 35D8 distributor on my í83 110 went tits up the other week. One of the advance weights worked itself loose, and promptly chewed up the inside of the distributor. Iím pretty sure itís toast. The particular distributor for my engine code is just about impossible to find, and the couple places that supposedly have it available list it for about $1100. That ainít happening.
So, Iím looking at this Pertronix unit as well. However, looking through the parts manual, between í83 and í86 there were no less than nine different distributors with five different vacuum units, each for a different engine code. Some of these are for points ignition, others are electronic ignition.
So, this raises a few questions:
1. Is this Pertronix D175510 distributor compatible with all early 3.5 engines? Itís my understanding that there are so many different distributors because they have different advance curves depending on the carb and vacuum setup for the different engine codes. Does this Partronix magically fit all of them and work correctly?
2. Does the stock Lucas coil and ballast resistor work with this setup? Some quick internet research seems to show that a points ignition coil should not be used with electronic ignition, and vise versa. Although it seems a lot of Series owners continue to use the points coil when they switch to Pertronix units in the four cylinder engine. Iím confused?
3. The vacuum unit currently on the truck is setup for use with two vacuum hoses. The newer distributors and this Pertronix unit are setup for only one. Will the current vacuum unit swap into the Pertronix, or do I need to do something funky with my vacuum lines?
Inquiring minds want to knowÖ
Cheers,
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Maybe start with an ignition upgrade? dnp Defender Technical Discussions 20 January 19th, 2007 09:30 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
