Performance Ignition Coil - Defender Source
Old May 26th, 2005, 09:30 PM
solihul
Rover
What is a direct drop in (wiring wise) to replace the stock ignition coil?
From the looks of it any round Accell or Mallory coil will just fit. Looks like all you have to do is remove the bracket, and move the male connectors to the new coil and drop it in.
There are also larger coils
http://www.centuryperformance.com/de...t_id=MAL-29450
that might work but I don't know where you would put that.
Any experience with coil improvements would be appreciated!
Old May 27th, 2005, 04:28 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I have the Jacob Electronics Energy Coil - drop in, nice and simple. With the Splitfire spark plugs, the JE wire set, they did wonders...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
coil
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
New STC1212G Amplifier Module Link Lead and Stock Ignition Coil nimbusnic For Sale - Parts 0 December 29th, 2008 04:54 PM
Who is the ignition module / pickup coil authority here? dnp Defender Technical Discussions 30 August 22nd, 2008 03:14 PM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
» Defender Registry
Billy
Highseas
ITP
RVR Gadfly
Add your Defender
