Pedal Pads, pedal pads, pedal pads - Defender Source
Join the Defender Source Community Today
Old July 8th, 2016, 02:33 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Anyone got recommendations for a D90(manual trans) pedal pad replacements other than the standard rubber set? I seem to wear through those in a couple of months.
I was thinking something along these lines, but I want to find a set that someone has already installed and can vouch for as far as fit and finish.
https://www.amazon.com/TIROL-General...dp/B00N1QEFUG/
Old July 8th, 2016, 02:39 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I have a cheap pilot set. Actually good quality. I don't remember if they were ALU or SS, but they haven't corroded and work well. Traction is superior. Only thing you have to get over is the holes that need to be drilled through your pedals. Once done, they are very secure.
Old July 8th, 2016, 02:43 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Got a make/model?
Old July 8th, 2016, 03:03 PM
Rovahfarm
Old July 8th, 2016, 03:09 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Originally Posted by Rocky View Post
Rovahfarm
Are you talking about these?
ZZPEDALKIT01
Brake, Clutch, Accelerator Pedal Pad Kit 11.95
Old July 8th, 2016, 03:12 PM
D90Overkill
David Frank
1995 ST #2615
I'll look them up on the web. I've had them on for 8 years, so I haven't got a clue what they were called. But they do have pilot written on the bottom of each pedal, otherwise I wouldn't even know that much ;-)
Old July 8th, 2016, 03:13 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I'll look them up on the web. I've had them on for 8 years, so I haven't got a clue what they were called. But they do have pilot written in the bottom of each pedal otherwise I would t even know that much ;-)
Or if you could snap a pic of them I will do the hunt.
Old July 8th, 2016, 03:19 PM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by wcampbel@nas.edu View Post
Are you talking about these? ZZPEDALKIT01 Brake, Clutch, Accelerator Pedal Pad Kit 11.95
Those are for series or VERY early 90/110, like a 1984.
Old July 8th, 2016, 03:27 PM
I gave trevor the sizes of the pedals I have (in classic LR fashion the size varies) and he ordered the right stuff for me.
Old July 8th, 2016, 03:41 PM
D90Overkill
David Frank
1995 ST #2615
Thank you. That would be better, And if I could, I surely would. Unfortunately, I'm in BC and my truck is in Portland, Oregon right now.
Old July 8th, 2016, 05:18 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Go pedal cover less. I've got just the underlying metal on my clutch.
Jimmy Buffett
Old July 8th, 2016, 08:11 PM
D90Overkill
David Frank
1995 ST #2615
That's what I had when I bought my truck. A bit slippery, though, which is why I added the metal traction pads. Mine are essentially what you have found in Amazon, save that I just installed the metal pieces with proper hardware and recessed the heads for a clean look. The holes in my pedals have a bit of a convex edge to them giving fantastic grip.
These are the closest I could find to what I have. Remember, I just didn't install the rubber/plastic grip inserts in favor of all metal to metal. Mine are also a bit more squared than what is currently offered.
Old July 8th, 2016, 11:01 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I have gone coverless before. But, it's a ST an and invariably gets wet in the footwell during summer storms. Super slippery with flip flops on, which is my preferred choice of footwear.
Perhaps a waterproof grip tape directly on the pedals?
Old July 8th, 2016, 11:51 PM
D90Overkill
David Frank
1995 ST #2615
I have gone coverless before. But, it's a ST an and invariably gets wet in there.
I had the same issue, but why not give the grip tape a try. You can always do the pedal pads if you're not satisfied.
Old July 10th, 2016, 10:03 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Skateboard deck tape. Waterproof and grippy. Going to order some this week.
Old July 10th, 2016, 10:30 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I ran a very plain set of Momo Alloy pedals on my 90 for 12 years. They worked great.
A lot of them now have rubber on them, not too fond of that.
pads
Dead Pedal and wider brake pedal defender1844 Defender Technical Discussions 6 July 3rd, 2016 01:52 PM
PEdal Pads Big D Wanted 2 July 25th, 2007 04:06 PM
Interior roll cage pads for 97 Wagon kevincdoyle Wanted 1 March 29th, 2004 09:25 PM
About to change brake pads whitelandy33 Defender Technical Discussions 13 December 19th, 2003 01:57 PM
Roll bar pads for SW Chaucer Wanted 3 December 3rd, 2003 02:44 AM
