PDWA swap after disc brakes upgrade? - Defender Source
Old June 8th, 2015, 10:04 AM
jafir's Avatar
jafir
Jafir Elkurd
I don't think I've asked this before, and my search didn't find too much on the subject so here goes:
If I upgraded my rear from drum to disc, do I need to replace the stock PDWA unit with one from a newer vehicle that had disc in the back? What about if I added vented front rotors and matching larger calipers? (I've got disco sized fronts at the moment).
It looks like my stock PDWA would have been NRC7871 or maybe NRC6515 and the newer version like what would be found on a NAS 90 would be NTC8836.
I've read some places that this component doesn't really do anything other than turn on a light if you loose pressure to a circuit. Instead of replacing it with the correct version (if that's even needed) could I just remove it and join the pipes together?
Old June 8th, 2015, 10:17 AM
You may delete the PDWA valve entirely and replace it with a T fitting.
Old June 8th, 2015, 10:38 AM
It is just a warning system. It does not affect the brakes.
Old June 8th, 2015, 10:47 AM
jafir's Avatar
jafir
Jafir Elkurd
Thanks guys!
Old June 8th, 2015, 11:16 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Pull it. It is IMO, a week link in the system. Instead of being a safety warning device it is a safety hazard (particularly older units). Mine drained the MC during a 1000 mi road trip, the sensor never illuminted. After tearing out the PWDA in a gravel parking lot and reconnecting the lines with some unions from the local auto parts store it has been great for the past two years.
1970 SIIA 88, Sold
brake
1970 Land Rover Series IIA - R380 Disc Brakes Rear Locker Jamooche For Sale - Vehicles 8 June 13th, 2013 08:53 PM
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
1985 110 front and rear complete axles with disc brakes willr For Sale - Parts 7 January 29th, 2011 08:20 AM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Disco disc brakes on Salisbury rear end Chris Velardi Defender Technical Discussions 10 November 16th, 2010 04:07 PM
