Passenger Headlight - Defender Source
Old October 7th, 2012, 02:06 AM
Spook's Avatar
Spook
Rich
97 Defender 90
Passenger Headlight
Anyone got any tips on swapping the bulb out or do I need to spend a couple hours removing all that crap.
TIA.
...Rich
Old October 7th, 2012, 09:09 AM
Replace them with hella e-codes while you are in there. The factory manual says 3 hours to change headlights ... Really it's about an hour for both sides. Remove marker lights, indicators and black trim ... 3 screws to remove headlight assembly. 3 more to remove headlight bowl from mount if you swap out the headlight from the assembly.
Old October 7th, 2012, 10:20 AM
Spook's Avatar
Spook
Rich
97 Defender 90
The driver I can get to from the back. The passenger has the fuel filter deal and some other box behind the light.
ht
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
D2 Passenger Side Headlight needed RoverChic Wanted 1 August 13th, 2007 03:01 PM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
