Passenger door won't unlock - Defender Source
Old January 27th, 2013, 04:03 PM
DOX's Avatar
DOX
Eric Doxey
1995 Defender 90
Tried searching and haven't come across this particular situation. I am not able to unlock my passenger door from the inside or from the outside, is it possible to remove the door card with the door locked?
Hopefully there is some magic trick to get the door open?
Old January 27th, 2013, 04:21 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Can you move the lock mechanism at all, or is it moving and not unlocking?
Old January 27th, 2013, 04:25 PM
DOX's Avatar
DOX
Eric Doxey
1995 Defender 90
I can turn the lock with the key about half way and same if I try and pull up the lock inside, won't pull all the way up.
Old January 27th, 2013, 07:36 PM
Bolson
Ben Olson
1995 Defender 110
re: door locks
I just replaced the drivers side door latch mechanism on my 95 D110 because I was experiencing the same symptoms ( not latching , not opening , door flying open when turning corners ie: seat belt check etc... ) I found to get the door open when it did not want to un latch I lifted up on the handle until I could get the latch to "pop" then I pulled the door card and swapped out the latch mechanism as well as replacing the striker
( got all the parts from Rovahfarm, good folks there... )
Old January 27th, 2013, 08:24 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Spray some WD40 in the lock from the outside. Repeat as needed.
Old January 27th, 2013, 08:27 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Maybe you truck doesn't like your wife/girlfriend.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 28th, 2013, 01:31 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Roll the windows down on both doors. On the drivers door, use a pin light and peer down to the latch mechanism inside the door, and push the outside button. Observe what happens. Now do the same for the passengers side. Also try pulling the door release handle (inside) while standing outside the D90. Observe analyse, repeat.
door
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Passenger Hand Grip Trevor Tarr Defender Technical Discussions 5 October 30th, 2005 02:47 AM
WTB: Passenger side carpet mat fleabus Wanted 2 October 14th, 2005 11:03 PM
AC relay in passenger area? artm Defender Technical Discussions 0 July 18th, 2005 09:53 PM
in the passenger seat compartment? januconn92 Defender Technical Discussions 15 April 2nd, 2004 10:08 AM
