Passenger Door Disassemble - Defender Source
Old March 5th, 2009, 09:19 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Hello, my defender passenger door rattles, and i would just like to know how to take the panels that covers the door on the inside off. Thanks
Old March 7th, 2009, 01:16 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
remove the handle -- two phillips screws
remove the finisher around the door latch--one phillips screw
remove the window crack -- spring wire between the handle and door
there are two grey "rivets" (top left and bottom right) push the center pin almost through and you can remove the rivets, be careful to not loose the center pin and you can reuse
then slide the panel up -- there are a series of two piece plastic "christmas trees" around the door--chances you will break some of them but they are a bit overkill -- my passenger door is down to about one third and it is fine.
consider treating the inside with a rust proofing or undercoat to prevent corrosion
Old March 7th, 2009, 07:55 PM
JohnsD90's Avatar
JohnsD90
thanks, thats great
door
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Passenger Hand Grip Trevor Tarr Defender Technical Discussions 5 October 30th, 2005 02:47 AM
WTB: Passenger side carpet mat fleabus Wanted 2 October 14th, 2005 11:03 PM
AC relay in passenger area? artm Defender Technical Discussions 0 July 18th, 2005 09:53 PM
in the passenger seat compartment? januconn92 Defender Technical Discussions 15 April 2nd, 2004 10:08 AM
