passenger axle leaking fluid - Defender Source
Old March 20th, 2008, 09:57 AM
cdb
Clark Bowen
The passenger side axle - where it comes out through the wheel flange - leaks so much fluid that it has spit off two of the rubber axle caps and covers the outside of the wheel with oil.
RN says it isn't a seal issue because it is supposed to lubricate that area and I don't have a parts schematic to dispute that but it seems there must be some issue or the other side would do the same. I did check the breather (ok) but the fluid is coming from the swivel balls according to RN.
Anybody had this problem?
Clark
Old March 20th, 2008, 10:39 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'd check the breather again... did you take the fitting off the axle and check for blockage?
Old March 20th, 2008, 10:42 AM
If its coming from the swivel balls couldn't you just switch over to the grease and eliminate the problem?
Old March 20th, 2008, 11:24 AM
cdb
Clark Bowen
I did think about the grease solution, but I wanted to find out what was causing the problem first. Also, if I take the D90 through water and any gets in my swivel balls, I figure the grease is hard to drain and replace.
And I did check that the breather and lines are venting correctly.
Clark
Old March 20th, 2008, 11:34 AM
The seals are probably bad... Go ahead and replace them, then put the grease in. I think it really is the best option. Just pick up some Molly Grease, it is the same as LR Grease.
Old March 20th, 2008, 11:40 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Use Series steel dust covers instead of the plastic ones a little silicon in the groove on the flange and it will never leak again.
Keith
Big, Red and ... aaa Red..
Old March 20th, 2008, 09:55 PM
cdb
Clark Bowen
I finally found a parts schematic and I can see an axle seal that may be the problem. I think I'll replace most of the seals and I really liked Keith's idea. I didn't realize the old Series caps would work.
Thanks everyone,
Clark
Old March 21st, 2008, 01:17 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Its a snug fit and it would be a good idea to get a piece of pipe or tubing to fit around the cap so you are pounding on the flange not the end, I use a piece of PVC conduit and a soft hammer.
Keith
axle
Axle Pressure and Too Much Fluid Wolf Fabrication Defender Technical Discussions 12 December 30th, 2009 03:26 PM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
transmission fluid leaking TravelerBT Misc. Chit-Chat 4 December 6th, 2008 09:02 PM
Leaking Axle seals? PCRover Defender Technical Discussions 8 June 4th, 2008 09:58 AM
