Parts Needed to Convert to a Soft Top? - Page 2 - Defender Source
Old November 24th, 2013, 12:50 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Can you show us pictures of what is not working out? I have ROW, NAS and MOD header rails here. Maybe I can help you though your issues Josh
legend in my own mind
Old November 24th, 2013, 04:28 AM
spammer
Samdford Wallace
95 RRC LWB / 86 Tithnous
Originally Posted by josh-man View Post
For what it's worth, The Badger just cut windows and a sunroof in my Genuine PVC top.... Sides roll up as explained
Wow. First Tithonus I have seen with a sand color top. I like it. I'd love to see more pics.
Old November 24th, 2013, 01:44 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Mine is not a Tith project truck. Just a run-o-the-mill ex MOD 110 three-door. You get the idea though.
Old December 4th, 2013, 04:06 AM
spammer
Samdford Wallace
Fraser was super cool and emailed me these diagrams. It appears that I only need the parts from the first diagram attached (header rail and channel). Can anyone confirm if any of the other diagrams have parts needed for the conversion for a Tithonus/Wolf?
Name:	Header rail and channel p351.jpg
ID:	85287   Click image for larger version
Name:	Soft top p353.jpg
Name:	Front roll protection p354.jpg
ID:	85289   Click image for larger version
Name:	Rear roll protection p356.jpg
Old December 4th, 2013, 12:36 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
You will need the header bar, vertical door channel ( LH RH ), horizontal door channel ( LH RH ) , and 2x hood tube supports and assorted brackets and bits. Tail gate with all of those fixings.
Old December 4th, 2013, 12:42 PM
Most all of those parts are available from Safari HP.
Old December 4th, 2013, 12:49 PM
solarguy's Avatar
solarguy
Abraham Bell
Not the door channels. The hood tube supports maybe if they fit another model.
Old December 4th, 2013, 01:15 PM
spammer
Samdford Wallace
I think I over looked the hood supports. Is that RRC8516 on the bottom right diagram? Thanks for pointing that out to me!
Old December 4th, 2013, 02:38 PM
solarguy's Avatar
solarguy
Abraham Bell
Yes. You are welcome.
Old December 6th, 2013, 03:48 PM
Blueduc
95 RRC LWB
Witham has a Wolf 110 hood up for auction-
http://www.mod-sales.com/auction/veh...r_Wolf_ECM.htm
Old December 6th, 2013, 04:19 PM
spammer
Samdford Wallace
I have heard that the ECM hood does not fit Tithonus vehicles properly. The main problem is the front where it attaches. It would require some modification to work. I wound up buying one off of eBay that Solarguy found for me (thanks!).
Old December 31st, 2013, 06:53 PM
spammer
Samdford Wallace
I'm struggling big time with this soft top. Am I supposed to be drilling the door top pieces? I can't figure out how they are supposed to fit. None of the holes line up. I am hoping someone can shed some light on how these pieces fit together.
The last pic looks like how it is supposed to.
ID:	86974   Click image for larger version
ID:	86976   Click image for larger version
Old December 31st, 2013, 07:30 PM
I'm in Arizona so what do I know about a Utah truck in California other than I dealt with this last month.
Old December 31st, 2013, 07:38 PM
spammer
Samdford Wallace
Weird comment Dave.
Old December 31st, 2013, 07:43 PM
Weird comment Dave.
You got your panties in s wad when I posted in your driving with headphones thread.
You were aggravated that I posted California law regarding it.
Good luck with the top, once again Google is all our friends. Both info and photos.
Old January 1st, 2014, 04:39 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'd slacken all the bolts off, including the roll cage, get all the bolts through their holes using a screw driver to pull anything way out of alignment so the bolts will go in then tighten everything up bit by bit. There's a lot of tolerance on a land rover, thats why nearly all the bolt holes are slots. My roof panel was inches out at my first go at fitting, the door gaps were all over he shop but it bolted up alright in the end.
Mike Hammond
part, parts, soft top, top
needed: roll bar parts, tailgate, soft top bstraw Wanted 3 March 21st, 2006 10:01 AM
Looking for "bar" on top of windscreen for soft top chuckc4 For Sale - Parts 2 March 8th, 2006 12:56 PM
WIng top shovel mount parts needed Cyborg Wanted 0 March 8th, 2006 11:12 AM
Soft Top to Station Wagon Ramsay Defender Technical Discussions 9 April 22nd, 2004 12:27 AM
Fiberglass top for Soft Top? boshea Wanted 1 April 20th, 2004 04:53 PM
