parts compatibility DII to D90 - Defender Source
Old May 18th, 2009, 05:54 PM
Anyone know if the following parts are a direct fit to the 90
[font='Arial', 'sans-serif']Power Steering Hoses Discovery[/font]
[font='Arial', 'sans-serif']Reservoir to pump NTC9989[/font]
[font='Arial', 'sans-serif']Box to reservoir (low pressure) QEH102370[/font]
[font='Arial', 'sans-serif']Pump to box (high pressure) ANR6656[/font]
AB lists the D90 hoses as
[font='Arial', 'sans-serif']Power Steering Hoses Defender 90 [/font][font='Arial', 'sans-serif']Defender 110: call[/font]
[font='Arial', 'sans-serif']Reservoir to pump '93-'95 NTC2595 '97 use ANR5782[/font]
[font='Arial', 'sans-serif']Box to reservoir (low pressure) QEH102380[/font]
[font='Arial', 'sans-serif']Pump to box (high pressure) NTC9099[/font]
and discovery Oil Cooler hoses (these are part of the package which i don't need but i wanted to check)
PBP101160
Oil cooler hose
PBP101150
Thanks the
Oil cooler hose
95' D90 - daily driver..
Old May 18th, 2009, 06:05 PM
I would loved to be told I am wrong, but the res is on the other side in a disco so none of these work and the oil cooler lines are different thanks to the different front cover at the very least. Pump to box "might" work, but I doubt it.
Old May 19th, 2009, 01:20 AM
check - that is what i though since the layout if different in the DII i believe even if the main parts arn't
Old May 19th, 2009, 02:43 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I stuck these numbers into microcat, with a "cross catalogue" search, and got:
[font=Arial', 'sans-serif]Power Steering Hoses Discovery[/font]
[font=Arial', 'sans-serif]Reservoir to pump NTC9989
[/font]
used on rangie classic 1992~1994 Tdi
[/font]
not listed
[/font]
defender 2.5l 300Tdi
disco series 1 1989~1998 LHD V8 and diesel
[font=Arial', 'sans-serif]Power Steering Hoses Defender 90 [/font][font=Arial', 'sans-serif]Defender 110: call[/font]
[font=Arial', 'sans-serif]Reservoir to pump '93-'95 NTC2595 '97 use ANR5782[/font]
[font=Arial', 'sans-serif]Box to reservoir (low pressure) QEH102380[/font]
[font=Arial', 'sans-serif]Pump to box (high pressure) NTC9099
[/font]
^^^ correct
PBP101160
shown as used on the 4.0 EFI V8 defender
Oil cooler hose
PBP101150
likewise, used on the 4.0 V8 defender.
90, d90, part, parts
D110 vs D90 parts chrisvonc Defender Technical Discussions 10 September 9th, 2005 07:36 PM
a load of D90 parts for sale ron For Sale - Parts 41 May 1st, 2005 03:32 PM
spring cleaning- D90 parts Chris Cox For Sale - Parts 13 April 4th, 2005 01:51 AM
D90 and Series Parts for sale rrubino2 For Sale - Parts 20 January 26th, 2005 05:31 PM
97 d90 LH drive parts steved90 Defender Technical Discussions 4 January 16th, 2005 08:23 AM
