part #'s for a 94 - Defender Source
Old March 27th, 2006, 07:01 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
part #'s for a 94
So i know what i'm asking for does anyone know theses part #'s
Where the hand brake cable comes into the cab it passes though a large rubber grommet which is in a sleeve,i'm looking for the grommet.
Also the pin which holds the two piece door hinge together.
Got my throwout bearing done sat,i started about 7.30 stripping out, Mike came round about 10.00 and we had the transfer case and tranny out and back in by 4.00.While we were taking it out noticed the engine mount was shot also the clutch master cylinder needs replacing.Thats next weekend taken care of.
3rd low and BOOT IT
Old March 27th, 2006, 07:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jimmy. I just checked the book and the grommit is not a separate part. It comes with the new cable only..
Also the pin in the hinge does not come separate either in the LR parts book...
Legend in My Own Mind.
Old March 27th, 2006, 08:16 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Do you have a pic of it (from the manual preferably). if it's the same as the RR one then I should have it. I should be back up on Thur or Fri and could bring it.
Try getting an engine mount from a Diesel Rover, they are stronger than the stock ones (Doug Walker can tell you where to get these). Or you could go with the QT bling bling ones but they are more money.
John C.
Old March 27th, 2006, 10:10 PM
Jack_Straw's Avatar
Jack_Straw
Greg
You could also use a Jag V12 mount if you want stronger than Rover but not as much $ as QT. They'll only fit in the engine, gearbox doesn't have enough room.
part
94 Oil cooler lines part number Defender50th Defender Technical Discussions 7 January 6th, 2010 03:59 PM
Seat Box Lid Part Numbers 94 NAS 90 Raleigh D90 Defender Technical Discussions 2 June 19th, 2009 09:57 PM
94 Radio antenna part # flippedrover Defender Technical Discussions 5 August 23rd, 2004 08:49 AM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
