part numbers for TD5 style tumblers - Defender Source
Old September 22nd, 2012, 04:20 PM
Many thanks!
Does anyone know what they are ... I need a set .. also is it possible to make a set match the NAS ignition ... or vice versa make the NAS ignition match the doors?
Old September 22nd, 2012, 04:34 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Tumblers are CWB000280MMM for 4 barrels and 2 keys.
I have no idea if the NAS ignition is compatible... I am guessing not considering how hard it is to find key blanks for them. You would think people would have just re-keyed them by now.
Old September 22nd, 2012, 04:49 PM
The key is the same format and my local lowes cut me one for about $3! It's a bit long ... Next time I'd cut 1/2 inch off the blank before starting
Old September 23rd, 2012, 12:09 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
To make the door locks compatible with the D90 ignition lock, you will have to get door locks (pull handles) from a 2006 or newer D90. The longer ignition key, requires a longer door lock cylinder, which fits in a different door handle made for the longer cylinder. Also, older door lock handles do not have the correct grooving to accept the ignition key even though it will insert part way. This subject has been dealt with in at least 2 other previous threads at length.
Old September 23rd, 2012, 09:21 AM
I have TD5 doors already .. I'm trying to get the tumblers to match the ignition.
Old September 23rd, 2012, 09:34 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
I would like to do this too, have the tumblers already in the NTO doors but no keys. Would be good to just use my 1998 ignition key to open the locks on the new doors. Can a locksmith reset the tumblers to work with my older ignition key? If there are previous threads on this, any links would be much appreciated!
Edit: OK never mind, found the thread w the pics etc
Cheers,
part, td5
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 04:55 PM
TD5 Part Numbers James Pierce Defender Technical Discussions 5 December 4th, 2010 04:30 PM
Part numbers for early 90? dave_lucas Defender Technical Discussions 2 July 4th, 2009 04:12 PM
D110 new style rear door part numbers brn24whl Defender Technical Discussions 7 October 26th, 2006 12:59 AM
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
