Part number for RoW V8 Ninety filler hose? - Defender Source
Old November 18th, 2017, 08:41 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Iím trying to figure out the part number for the rubber hose that runs between the filler neck (which is the big one, itís like 3Ē across) and the top of the (side mounted) petrol tank. Anyone know?
Thanks in advance
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old November 18th, 2017, 09:39 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
This might get you close.
http://www.allbrit.de/select.cfm?PAG...=L1&SPRACHE=EN
This is maybe closer?
http://www.allbrit.de/epc.cfm?PAGE=I...=L1&SPRACHE=EN
Sorry, don't know much about this particular ROW.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old November 18th, 2017, 10:10 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
well a quick look at rovafarm this came up NTC2338, side mounted tank is what you got?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 19th, 2017, 11:01 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks all, just ordered one from RN.
Old November 20th, 2017, 01:01 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update: Turns out I need NRC9291. Which is $283.63. Bollocks.
Old November 20th, 2017, 01:06 PM
https://www.thexmod.com/item_detail.asp?id=1155
Old November 20th, 2017, 05:51 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks John!
Old November 20th, 2017, 06:58 PM
roverman2010
1985 LR 90 200Tdi
It's strange that you need the $ one as both ours are the same age and the cheaper one fitted like a glove on old red. Can't see it being that a V8 is differant in that regards??
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 21st, 2017, 11:16 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I donít get that either. I presume yours has the huge opening too? If it ever quits raining, Iíll go get more photos so we can compare.
Old November 21st, 2017, 11:24 AM
Is it the tank end? Maybe the early tanks were different and John's was replaced.
Old November 21st, 2017, 11:28 AM
roverman2010
1985 LR 90 200Tdi
The only thing that I changed was the metal fill pipe off a S3 had to cut down in lenght as I misplaced my expensive fuel cap on the A6 nr cannock, but didn't change the hose. I can still remember seeing it sitting on the fuel pump. Grrr
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 21st, 2017, 12:57 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Hereís a shot of the offending hose. For some reason, the uploader decided to rotate the pic 90 degrees...
Old November 21st, 2017, 03:07 PM
roverman2010
1985 LR 90 200Tdi
Ditto, by the way the metal fill pipe attached to the wing is 70mm dia.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 21st, 2017, 03:24 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Maybe Iíll give NTC2338 a shot.
Old November 21st, 2017, 03:28 PM
roverman2010
1985 LR 90 200Tdi
Why not phone Trever at rovafarm and ask if he could measure one, or Zack if they have one.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old December 6th, 2017, 09:02 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
PLM197 is NOT the correct part.
I’ll ret a NTC2338 next.
Edit: Per RN, PLM197 replaced NTC2338. Well bollocks...
------ Follow up post added December 6th, 2017 06:08 PM ------
What is the part number of whatís shown in your pic?
Old December 6th, 2017, 10:41 PM
I'm confused. I thought you already determined NTC2338 was wrong and you needed NRC9291.
Old December 6th, 2017, 10:45 PM
Do you have a copy of the early 90 parts catalog?
Old December 6th, 2017, 10:47 PM
The change in part number is by your VIN number. Pre and Post VIN 259679. Looks like the tanks changed around that time. Looks like the filler on the tank moved outwards on the later tanks.
Old December 6th, 2017, 10:52 PM
You better get that outrigger changed!!!
part, v8
fuel filler hose Rowdy90 Defender Technical Discussions 3 June 28th, 2013 01:08 PM
RN Part Number Cross Reference? GYM Misc. Chit-Chat 2 May 13th, 2011 11:55 AM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
