Part ID ? Under lower swivel pin - Defender Source
Old May 10th, 2010, 01:01 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
came with my 'new' swivel housings. Two flathead screw threw it and retain the lower swivel pin. Big heavy bar. Small tab mounts the brake sheild.
What the heck is it for? Left it off for now.
Old May 10th, 2010, 01:55 PM
16kpsi's Avatar
16kpsi
Tony Lawson
figured it might be something like that.
So worth putting back in I guess. To dampen some harmonic of some sort. Like there aren't a thousand other vibrations....
thanks
Old May 10th, 2010, 02:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Jeff- Are those things OE?
His was the first I had ever seen...
Old May 10th, 2010, 03:16 PM
I have seen them before. I thought they just held on the brake shield.
Old May 10th, 2010, 03:24 PM
16kpsi's Avatar
16kpsi
Tony Lawson
I seem to remember them on my '94 d-90, but my memory is dim. I only ever did brakes on that truck, never got into the swivels, so no clear memory of them in my hands. Funny how working on cars makes for deja vu memories.
no part shown in my 1987-2001 parts catalog. Wierd.
wait.....big heavy weight mounted under the diff? The Earth?
Old May 10th, 2010, 08:14 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have seen them on RRC's but not on 95 or 97 d-90's
Legend in My Own Mind.
Old May 10th, 2010, 08:21 PM
I think they go with the big rubber damper disc thing on discos and RRCs now that I think about it because the NAS 110 axles don't have them and niether do the D90 ones.
Old May 11th, 2010, 01:59 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yup, Harmonic Damper Weights.
My 96 D1 has the round heavy weight on the front diff housing and those long weights on the swivels. My 97 D90 has the long weights on the swivels but not the round weight on the diff. My 98 D1 has both the swivel and the diff weights again. So I guess some 97 D90s had them on the swivels and some didn't.
Glad the D90 doesn't have the diff weight as they are really, really easy to knock off.......
Early/Mid 80s and early 90s Euro RRCs didn't have either, nor did mid 80s Euro D90s. At least not the ones I have owned.
Name:	Diff Weight.jpg
Old May 12th, 2010, 12:44 PM
RonL's Avatar
RonL
Ron LeFevre
1997 & 1999 Disco
it holds the lower "dust shield". See pic...
part
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
Swivel pin shims KevinNY Defender Technical Discussions 23 July 17th, 2007 06:31 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
