Part ID - Defender Source
Old October 5th, 2013, 12:38 PM
irishwoody97's Avatar
irishwoody97
Woody
1983 One Ten County, Blue/White
Part ID
I have finally received my One Ten from Germany after the engine swap. Unfortunately, the mechanic had to leave a part off after the swap. Now I am trying to identify the specific part in order to order and install it. With my detailed shop manual (temporarily missing after the move), I was hoping one of you could help.
As you can see in the photo, I need the panel covering the gearbox, which would then have the rubber boots attached to cover the shift levers.
Details:
'83 One Ten
3.5 L Rover V8
LT85 Gearbox
Any help is appreciated.
Woody
Old October 5th, 2013, 12:56 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
It appears that you need MUC4319. MicroCat shows it being NLA, but you shouldn't have too much difficulty finding one. I don't have much firsthand experience with the LT85's, but I believe the insulating pad you need is MUC4027, and the shift boot is BTR1698.
Geared Restoration Co.
352-572-3236
Old October 5th, 2013, 01:05 PM
irishwoody97
Woody
Thanks, Ash. I'll check it out.
Rancho 9012's, part number??? artm Defender Technical Discussions 0 November 9th, 2004 07:01 PM
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
