parking lights come on when brakes are pressed!? - Defender Source
Old June 21st, 2013, 05:06 PM
wantone
Rick Thompson
94 ST #1222
hello all! i just noticed that all of a sudden when i press the brakes, the front parking and side lights come on, of course only when the headlights are off. all the lights, work correctly, backup lights, brake lights etc. i recently replaced a brake light bulb, could that have done it? and if so, why?
thanks
Old June 21st, 2013, 05:11 PM
Mine did this, but at the same time my brake lights weren't working properly. I had corrosion in the rear light connnections, and when I spliced in new ones, the issue stopped.
Old June 22nd, 2013, 07:12 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Since it is effecting both front and rear lighting I would look at the light switch and then your grounds.
Old June 22nd, 2013, 07:14 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
bad ground ......
No Mall crawler here
Old June 22nd, 2013, 08:45 PM
wantone
Rick Thompson
94 ST #1222
Any idea on which ground to look at first? I assume the tail lights?
Old June 22nd, 2013, 09:04 PM
The ground for the lights.... LOL. Look for a common ground for the lights. Basically the electricity goes from the brake light ground into the ground of the other lights and turns them on. The common ground is not connecting to the vehicle ground and the battery.
Old June 23rd, 2013, 06:57 AM
Capt Milks's Avatar
Capt Milks
You have a main ground at the engine side bulkhead and another ground in the area of the chassis harness where it comes out of the frame or by the RH rear harness inside the tub. Some of these grounds have multiple wires, all black in color. Look at the connection but also at the wire itself. You may have to cut the wire back a bit to get to a good non-corroded wire. You will be able to see the copper wire turning green to black if it is bad.
Old June 23rd, 2013, 09:20 AM
wantone
Rick Thompson
94 ST #1222
Found the problem. A week ago i came out of the restaurant & noticed my tail light out in the reflection of a building so i pulled the reverse bulb to get home. Few days later go to napa & new bulb but i put it in the reverse lamp. Well as you all know the brake light bulb has two filaments & the reverse bulb only one. So after a few days of driving i guess it blew the FUSE & started the problem. Only when i noticed the tail light out again did i check the bulb & it was fine so i knew it had to be the fuse from using the single filament bulb. Thanks for the suggestions everyone!
lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Rewiring all rear lights - Electrical Issues rijosho Defender Technical Discussions 34 December 16th, 2015 01:35 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
