Parking lights and side markers won't turn on - Defender Source
Old February 1st, 2015, 02:53 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
It seems it's always something. Yesterday I turned on my parking lights as I normally do when driving just before dusk. The left side all went on (driver side) but the right side didn't. Also noticed the right side marker lights didn't illuminate either. Only thing I have done lately is replaced one of the side marker lights with a new bulb from RN (fit perfectly and has worked for a week since).
Adding to this is if I put on the Hazard switch all the parking lights and side marker lights go on but the right side that was not going on before and side marker lights all "blink" in unison with the turn signals but the left side do not blink (as they shouldn't).
I should add the turn signals, headlights and brake lights on all sides work through all this.
Thoughts before dig into this?
Old February 1st, 2015, 03:44 PM
wmatos1001's Avatar
wmatos1001
William
Did you check the fuse(s) the right and left on on separate circuits.
-Jeff
Not yet not sure what to look for. I assumed (maybe wrong) if the fuse was bad they wouldn't go on at all? But they do go on and "blink" when the hazards are on?
Will
Old February 1st, 2015, 05:28 PM
wmatos1001's Avatar
wmatos1001
William
Again, the right side is on a separate circuit/fuse than the left. If you are missing the fuse panel cover with the 'map' do a google image search and one will come up for your year.
-Jeff
Awesome thanks, will do!
Old February 21st, 2017, 06:22 PM
DGC
Graham Carroll
1995 Defender 90
Did you ever get an answer to this? I am experiencing an issue where the right rear red light works when I apply the brakes but does not illuminate when I turn the running/headlights on. Trying to diagnose...
Old February 21st, 2017, 06:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You have at least one bad ground and possibly a burned out fuse.
If you remove the fuse box cover, there is a legend that will show what fuse goes where.
RDavisinVA
Old February 21st, 2017, 06:33 PM
DGC
Graham Carroll
1995 Defender 90
Awesome thanks for the guidance! will poke around and see what I can find
Old February 21st, 2017, 08:05 PM
gwmckee
George
1994 NAS D90 #1919
You might want to try ruling out the bulb as the culprit first. I think those are duel-filament bulbs so one or the other filament could burn out but the other still work. Easy test... swap bulbs between the left and right side. If it's the bulb, it won't work on the other side either. If it's the fuse or ground, the working bulb from the other side won't work when you swap it in.
Old February 21st, 2017, 08:15 PM
DGC
Graham Carroll
1995 Defender 90
good strategy. i like it. will try and report back
Old February 25th, 2017, 04:06 PM
DGC
Graham Carroll
1995 Defender 90
the wiring on the left stop light is too short for me to pull the assembly out all the way to unhook it and swap to the right side....going to just order a new bulb for the right side and see if that fixes it. It so, would be a cheap fix.
Old February 26th, 2017, 10:11 AM
gwmckee
George
1994 NAS D90 #1919
That's what I meant in my post. Just move the bulb on the left to the right hand socket, and the bulb on the right to the left and socket. See if they work. That should tell you if the bulb is good or not.
Old February 26th, 2017, 10:25 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
George is suggesting you remove the lens cover and then take both bulbs out and switch them, not swap the entire lamp assemblies.
RDavisinVA
ht, lights
Turn, Stop and Markers from Defender 90 Dogpilot For Sale - Parts 3 February 18th, 2014 12:32 PM
NAS Headlight Bezels, Turn Signals and Parking Lights bradfordish For Sale - Parts 4 December 11th, 2013 01:45 PM
Which side markers to use? Maximal Defender Technical Discussions 3 February 18th, 2013 09:21 AM
Clear side markers but NAS style? RoverC Wanted 0 March 26th, 2008 08:53 PM
new, euro-d90 side lamp markers thewap For Sale - Parts 0 June 20th, 2006 01:45 PM
