parking brake switch - Defender Source
Old September 20th, 2005, 09:29 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Anyone know where I can get the small plunger style switch under the brake lever? It isn't working and the brake light isn't functioning correctly.
Rich
I checked AB and RN and didn't see the same thing.
Old September 20th, 2005, 11:56 AM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
https://www.expeditionexchange.com/genuine/
scroll down a bit.
Defender Brake Switch (PRC4297) $30
Insert pithy quote here.
Old September 20th, 2005, 11:57 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
IIRC a lot of alarm systems use the same type of switch for the hoods and sometimes for doors as well. Maybe try taking the old one down to an alarm place and see if they can get one for you?
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 20th, 2005, 01:10 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks.
Read, I think that is for the brake pedal isn't it. I need the one for the transmission brake. Maybe I can use Hans advice and just use a alarm. I just thought it would be easier if I could just find one.
Rich
Old September 20th, 2005, 02:54 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Im sure RN or the local dealer can get it for you too. Just call up RN.
Legend in My Own Mind.
Old September 20th, 2005, 02:58 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Randy,
I found one from Mike McCollum at Land Rover West Chester.
Old September 20th, 2005, 08:45 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
you're right. should have read that a little closer.
brake, switch
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
