Parking brake retrofit advice - Defender Source
Old April 13th, 2009, 10:47 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Got the D1 transfer case installed yesterday (huge thanks to Bill Campbell, Ray and Patrick). Next issue is to figure out what to do about a parking brake. The existing parking brake cable bracket will not bolt to the D1 LT230 short of drilling and tapping the case. Which would be a pain. I have a D2 cable and the majority of the parking brake assembly, though not enough to actually actuate the brake or attache the cable to the drum. in this thread: http://www.defendersource.com/forum/showthread.php?t=18269&highlight=d2+parking+brake
it appears relatively simple to retrofit the D2 cable to an NAS 110 handle -- so it would appear that my best course of action would be to source a complete D2 Parking brake assembly and throw it on there. Other options include the x-eng disc brake (which seems to be expensive overkill) or wheel chocks. Thoughts?
Tony
Old April 13th, 2009, 11:30 AM
Real men use dual wheel chocks on chains
Glad to hear you got you tcase in. So is she on the road now?
Old April 13th, 2009, 12:20 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Not quite, need to rebuild the D2 shaft for it and get the parking brake figured out so that the rear shaft can go on. I did run her through the gears, though, and things that are supposed to spin spin.
Old April 13th, 2009, 04:49 PM
tony. why not use your 110 front shaft?
handbrake from a disco 1 should work, same exact parts as what is on my tdi gearbox. get the one where the cable goes directly into the backplate.
real men just leave it in gear. or so I heard.
Old April 13th, 2009, 06:06 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Going with a d2 shaft because I had the flange, Ray's hooking me up with the shaft and with 2 inches of lift it can't hurt.
Tillery's trying to dig up a D2 brake now, I'll see if he has a D1 brake
Old April 13th, 2009, 11:39 PM
did some checking think the d1 cable is shorter. but the 90/110 one looks like it has the same end.
brake
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
