Parking brake light - Defender Source
Old September 27th, 2004, 12:24 PM
howellm70
Michael Howell
Parking brake light
My parking brake light comes on (or flickers on and off) when I'm going down a steep decline...when I hit the flats it goes out w/i 30 seconds. Not a terribly big deal but anyone have any ideas as to what might be causing this to happen...or how I can fix it?
Thx
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old September 27th, 2004, 12:30 PM
check your brake fluid level. the resevior is underhood on driversside fire-wall.
Old September 27th, 2004, 12:32 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
quick fix take the bulb out
Old September 27th, 2004, 12:40 PM
hmm. thats there for a reason, you wouldnt say take the bulb out for the check engine light or low oil pressure? also it could be the parking break needing adjustment, I am not to certain about that although it has been disccussed in the past.
Old September 27th, 2004, 02:19 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Thx
While Phil makes a good point about the brake fluid I too had this problem, but it turned out that the wire on the hand brake sensor-switch was almost severed. Remove the rubber boot on the hand brake and check to see if the conncection is still in good shape.
DJ
brake, ht
Parking brake light ... Retrofit Defender Technical Discussions 12 June 26th, 2016 05:59 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
