Parking Brake Light - Defender Source
Old October 24th, 2011, 11:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
Parking Brake Light
I noticed tonight that my parking brake light comes on when I start the car but it then shuts off even if the parking brake is on. Could something be loose?
Old October 25th, 2011, 12:01 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Loose or more likely the switch is out. A lot of people replace the switch, but I have successfully repaired my switch and one of my friends. Both of our springs broke in the carrier. The plunger is easy to take out--just slightly and carefully pry the sides back just enough to slip the catch by. Our springs were in two pieces. I used a spring from a push-button pen and cut off a small part of it to make them the same length. Working on about 3 years of the "refurb"...
Old October 25th, 2011, 12:11 AM
bjf's Avatar
bjf
barry f
94 ST #395
where is the switch?
Old October 25th, 2011, 01:20 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Take the boot off the handle--you will see it screwed to the side of the lever. Two screws hold the lever onto the seat box.
Old October 25th, 2011, 01:29 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks and I assume a loose wire would be there too
Old October 25th, 2011, 01:35 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah--the wire comes through the seat box between the two retaining bolts and it is a simple spade connector which could have worked loose as well (but so far I have just seen switch failures).
Old October 25th, 2011, 01:58 AM
bjf's Avatar
bjf
barry f
94 ST #395
Ok will check. Sounds like an easy fix
Old October 27th, 2011, 10:54 AM
bjf's Avatar
bjf
barry f
94 ST #395
Whats the part number for the switch?
thanks
Old October 30th, 2011, 07:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
No one has a part number for this?
Old October 30th, 2011, 07:58 PM
it will also blink if the fluid resevoir is low
Old October 30th, 2011, 08:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Opened it up. Switch sticks and light only flickers if I play with switch
Old October 30th, 2011, 08:54 PM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
I need to address this issue with my truck. Whats the best way to access the switch, through the center seatbox panel or from underneath?
Old October 30th, 2011, 09:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
Take the boot off the brake and you will see the switch
brake, ht
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
