Parking brake light ... - Defender Source
Old February 16th, 2009, 10:17 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I know we all (most of us ...) have a parking brake light in the dashboard. I would like that one to work for me, I have all the wiring out and ready to plug but I was wondering if there was a stock microswitch for the LT230's parking brake ? I mean there is a light ... shouldn't there be a switch somewhere ???
Thanks all
Pat
Kirk Lazarus, Tropic Thunder
Old February 16th, 2009, 10:47 AM
It is on the handle.
Old February 16th, 2009, 10:58 AM
cabell's Avatar
cabell
Cabell Crowther
Pat, some early handles didn't have the swicth. There is a thread on lr4x4 on adding it. I've added the switch to mine but could use some help on the wiring. How is your wiring configured?
Old February 16th, 2009, 02:36 PM
Retrofit's Avatar
Retrofit
Pat
Well ...
I have looked over most popular UZ OZ forums and yes it is on the lever but mine is not equipped and would like to see a picture of one before ordering parts ... or diagram for that matter ... anyone have one to sell ???
Thanks again !
Pat
Old February 17th, 2009, 03:49 PM
cabell's Avatar
cabell
Cabell Crowther
Safarirover has some LHD handles with the switch on them. Not sure if he has RHD.
Old February 17th, 2009, 05:56 PM
Retrofit's Avatar
Retrofit
Pat
Cool ...
Worth the try, will PM him !
Thanks Cabell
Pat
Old February 17th, 2009, 07:04 PM
surf110's Avatar
surf110
Ze
130 Project
This is what the switch looks like.
Old February 17th, 2009, 10:15 PM
Retrofit's Avatar
Retrofit
Pat
You couldn't have done it better, a picture is worth a thousand words ... Parts on order !
Thanks allot !
Pat
Old February 18th, 2009, 12:42 AM
surf110's Avatar
surf110
Ze
130 Project
Thanks allot !
Pat
You're welcome. Just glad I could help out.
Old June 25th, 2016, 09:43 PM
Resurrecting an old thread - I have an older style that doesn't have a switch (like the one pictured above). Dash light doesn't work. Thoughts on how to check wiring? Do these older style just make a ground contact when engaged? I don't see any electrical cables coming from the lever, only the mechanical cables; however, I'm fairly certain I'm not looking in the right place. Thanks in advance for any tips.
Old June 25th, 2016, 10:00 PM
You may not even have a switch installed or have provisions for one in a 1986 truck.
Old June 26th, 2016, 12:03 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Yes, it just grounds out. The wire, if you have it, is white with a yellow stripe. It carries voltage from the lamp to the switch, which grounds out and completes the circuit.
Old June 26th, 2016, 05:59 AM
Thanks guys - I'll check again.
brake, ht
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
