Parking brake circuit - Defender Source
Old November 29th, 2008, 12:13 AM
flynn23
Scott Kozicki
97 NAS D90 SW
Does anyone have a schematic for the parking brake idiot light? Mine flickers and sometimes sticks on. I checked the switch on the hand crank and even if fully depressed (as to show it as being OFF) it still shines on. I haven't gotten into cracking open the drum to check it out, and it doesn't drive like it's on, but wanted to check the electrics first, since that seems to be the problem, rather than the drum itself. There's only one wire running out of the sensor on the hand crank, so I'm assuming that if it's grounded, that means the circuit is open.
Old November 29th, 2008, 07:28 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
On a 95, this light is also tied into to your brake fluid resevoir level. Make sure it's topped off. When you remove the cap, you'll also notice the sensor tied to the cap, 2 wires coming from it IIRC. These wires will be positioned 90 degrees from centerline of your truck. If the topping off doesn't solve your problem, then loosen the cap and rotate the sensor to where it's 45 or 135 degrees from centerline and re-tighten while holding the sensor in this position.
The procedure for setting the transmission brake is in your owners manual, if you haven't already gone through that.
brake
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
