Parking Brake Adjustment - Defender Source
Old June 25th, 2014, 08:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is it easy to adjust a parking brake? On mine I have to pull it way up to engage it and sometimes when I push it down it doesn't shut the light off unless I give it a tap. I assume the cable is loose? Any help is appreciated.
Old June 25th, 2014, 08:15 PM
it is but you have to get dirty. 13mm and 17mm (IIRC). adjust to 3 clicks. going to have jack a whell up to get drum to spin by hand. use adjuster nut on drum to tighten til won't spin, than back off a click or two til it will without resistance. that is using 13mm wrench
if you fell you need to shorten cable, then it gets more painful. well covered in manual.
Mark Kellgren
KM4BOR
brake
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake circuit flynn23 Defender Technical Discussions 1 November 29th, 2008 07:28 AM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
