Panhard Rods and Geometry - Defender Source
Old March 21st, 2012, 12:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
In theory, if you lift your truck, say 5", wouldn't the Panhard rod be longer according to the Pythagorean theorem (a2+b2=c2).
I've got my adjustable panhard rod situated after squaring up the axle and it's shorter.
Anyone?
Semper Fi!
Old March 21st, 2012, 01:42 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Anyone?
If I remember correctly from my 9th grade trigonometry class, it has to be a right triangle for that to work.
MUDSUX
Old March 21st, 2012, 02:01 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
But yes, the panhard rod would need lengthening slightly if you lift the truck 5", but it's not much, probably only 10mm or so, maybe 20 at a push.... only enough to centralise the axle under the chassis again.
Old March 21st, 2012, 02:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
It is a right angle triangle. You just have to imagine it in the proper plane. Imagine straight across the axle but coming under the upper panhard mount, then up at a right angle to the upper panhard mount, then from there down to the panhard axle mount.
It all makes sense when using a plumb bob.
Semper Fi!
Old March 21st, 2012, 02:19 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
You will have slight pull on the right side which will start to turn the right side around ever so slightly. You will feel the truck always feeling like it needs an alignment when you drive on the highway. Its not terrible, but you will notice it.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 21st, 2012, 06:26 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
If it is a right triangle, then Pythogoras owes me an apology for doing so badly in Trig
MUDSUX
Old March 21st, 2012, 06:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
It's a right triangle in my head, that's all that matters. Probably why I can't balance my checkbook.
Semper Fi!
Old April 1st, 2012, 07:27 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
x2. I lifted our d-90 ST with Rovertym 4" springs and it was about 10mm that I had to lengthen the Panhard rod. Definitely odd that you have to shorten yours. You obviously didn't use the stock one because it's not adjustable... did you use the exact same rod before the lift vs. after?
Old April 1st, 2012, 07:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
I have an adjustable rod. After lining everything up it ended up being longer, about 1/2".
Semper Fi!
Old April 1st, 2012, 07:46 PM
cbass's Avatar
cbass
Bradlee Duncan
That sounds better :-)
