Panhard rod woes - Defender Source
Old May 27th, 2008, 12:34 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Panhard rod woes
So about a month ago I swapped out my panhard rod bushings in an attempt to fix my crappy steering. Didn't fix the problem but yesterday I went wheeling and afterwards the front end was wobbling uncontrollably. The bolts were moving around like crazy inside the mounts when i turned the wheel back and forth. I will change them again but I don't understand how five miles of wheeling will trash month old bushings? Is there an after market setup someone has experience with that might be better?
Old May 27th, 2008, 12:47 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
What bushings did you use? I know that certain aftermarket companies bushings are absolute crap.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old May 27th, 2008, 03:31 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
wHAT ABOUT THE BOLTS? How did they look? were they worn?
Legend in My Own Mind.
Old May 27th, 2008, 05:08 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
DOn't know, I ordered the bushings from AB. As for the bolts, they were fine. I'm going to change them this time though.
Old May 28th, 2008, 08:47 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
make sure the bracket holes arent elongated giving the rod play thus detroying the bushing.
also make sure they are torqued
Old May 28th, 2008, 10:05 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Do you happen to know the torque setting?
Old May 28th, 2008, 11:42 AM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Pan Hard Rod
Consider installing a bolt through the Pan Hard Rod Bracket mounts that is full length (unthreaded) for the portion that rides between the two mounts (at both ends). I am surprised that apparently the original LR bolt does not cover the full distance of this mount and thus sets up a condition for the bushing to have two different surface types to ride on, one unthreaded, one threaded. Threaded surface for a bushing is never a good thing. I aquired a grade 8 bolt and nylock for this application. I also used the same type hardware for the Pan Hard rod mounts to the frame. Where the Pan Hard Rod is mounted in a shear application, you have got to get the bushings riding on an unthreaded surface otherwise you'll set up a condition that hard to correct and what some try to correct w/ overtourqing these bolts. With this set up and the use of a nylock, tourqing the bolts to just snug is sufficient.
Panhard Rod Bolts kellymoe For Sale - Parts 2 October 27th, 2005 07:18 PM
RoverTym Adjustable Panhard Rod cbass For Sale - Parts 3 August 16th, 2005 12:41 AM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
