Panhard rod - left to right - Defender Source
Old June 26th, 2013, 12:41 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
So - I don't want to go over my whole project. It's here if your interested/bored:
http://www.defendersource.com/forum/...ad.php?t=29886
I'm LHD now. Installing the P38 steering box because of my build. It creates an issue for the panhard mounting because this box hangs down so far (and is therefore stronger at the output bearing. anyway...). A friend suggested I could swap just the panhard mounting back to the RHD side. I have the RHD upper bracket (I'd reinforce this as it used the steering box as a partial brace). Axles are all built with both handed mounts.
Only issue I could see is bump steer: as the front suspension compresses, the arc/left hand motion of the axle would create a right hand steering input. In bad design cases, this can create a real drivablility issue and oscillations. Anyone heard of, seen, driven a vehicle set up this way? The defenders are pretty spongy and have a fair amount of bump steer as is....
Panhard Rod Bolts kellymoe For Sale - Parts 2 October 27th, 2005 07:18 PM
RoverTym Adjustable Panhard Rod cbass For Sale - Parts 3 August 16th, 2005 12:41 AM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
