Panhard Rod Bushing Replacement - Defender Source
Old August 24th, 2007, 03:15 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Looking for some tips on how to replace these bushings without a press. I just bought a '91 GDE Range Rover and the bushing on the rod are completely shot to hell.
I've heard of burning the rubber out with a torch. What's the best way to get the metal rings out? And putting them back in? Hammer or vice?
Any tips from experience would be great!
- Chris Snyder
Old August 24th, 2007, 05:03 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Spend $10 and go to a shop with a press. The metal sleeve has likely rusted to the inside of the panhard rod and it will take an afternoon of burning stinking rubber and a hack saw blade or two before you get the original one out. Then you will beat the new one senseless getting it in again.
Trust me go to a shop then you can spend the afternoon wondering why they still pop when you turn even though you used the factory torque spec. From my experience you will need to crank the things tight.
Old August 24th, 2007, 10:48 PM
bjenk
Brian Jenkinson
1994 D90
I ended up buy a press to do my panrod and u joint. I tried to use a vise (HUGE VISE at the firehouse) and I ended up bending the vise handle. My little press got them out, but it was scary!!! I ended up wrapping a towel around just in case. I bought my press used, it is the harbour frieght one.
If anyone in Colorado needs to use it just give me a call, I am in morrison. It knocked out the u-joints no problem.
brian
720-219-2288
ac
Panhard Rod Bolts kellymoe For Sale - Parts 2 October 27th, 2005 07:18 PM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
rancho bushing replacement? jorge Defender Technical Discussions 6 April 7th, 2005 03:36 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
