Panhard Rod Bushing Question - Defender Source
Old December 29th, 2004, 10:17 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I searched first I promise.
So I'm swapping out the panhard rod bushing this weekend and don't own a shop manual. Do I need a torque wrench or is it just a "make it tight"-er type bolt.
Thanks in advance!
"It's not a Jeep"
Old December 29th, 2004, 11:03 PM
They MUST be torqued. The inner sleeve will move around and steering will be loose if you don't. I think it is 120 lb-ft.
Old December 31st, 2004, 03:19 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Might be a little off topic, but after replacing my panhard bushings several times, I installed Rovertym's adjustable panhard rod. A few nice things about their design: 1) you can adjust the length to compensate for geometry changes due to lift, 2) it has a heim joint on the steering box end (should not be susceptible to damage from steering fluid dripping onto it like the rubber bushing is), and 3) it retains the bushing on the diff end so you still have some damped compliance in the system. The truck feels tighter after this change, and there is no noise from the heim. Not sure yet what it does for articulation but should be the same or better.
Old December 31st, 2004, 08:45 PM
Just had a look in the manual
130 lb-ft
Panhard Rod Bushing Replacement cellulararrest Defender Technical Discussions 2 August 24th, 2007 10:48 PM
Bushing hardware question D90user Defender Technical Discussions 3 November 30th, 2005 03:54 PM
Panhard Rod Bolts kellymoe For Sale - Parts 2 October 27th, 2005 07:18 PM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
