Panhard pre- load questions - Defender Source
Old February 25th, 2009, 02:14 PM
I have my adjustable panhard rod ready to install. The truck has 3 or so inch lift and there is considerable load on the stock panhard rod-ie front axle is pulled to the left, not centered. Should I simply remove the stock rod and adjust the new one out so there is no load ? Its easy enough to pull the truck sideways using the winch so the question is how much preload is correct ? 1/2 inch, more, less ?
For anyone interested these are German made by a company called Atek and can be had from Paddocks with poly bushings for less than you can make your own-$68
http://www.paddockspares.com/pp/NEW_...nhard_Rod.html
Old February 25th, 2009, 05:42 PM
somebody has got to have this knowlege here
Old February 25th, 2009, 08:39 PM
I took mine off a few years ago, lined up the holes from the stock one and installed it. I have not had any issues.
Old February 25th, 2009, 08:43 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
With mine, I adjusted the panhard to center the axle. HTH. Mark
Old February 25th, 2009, 08:48 PM
Doesn't the truck self center the front axle on the coil springs/shocks if you remove the panhard rod if its sitting on level ground?
Old February 25th, 2009, 08:51 PM
johnpiero
John Brancato
none
After my ordeal a couple months ago, i consider myself the panhard master.
What I did was remove the old panhard and cautiosly but strongly pushed the body until it was as centrally aligned over the front axle. Once aligned, I adjusted the panhard rod so that the bolts slipped right in. Then i cranked down to bolts.
Pushing the car was the hardest part because I was very concerned that the body would go too far and cause damage....but it didn't and took quite a bit of shaking.
Old February 26th, 2009, 02:04 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
This is what I did as well.. Get it centered and you are good to go..
Legend in My Own Mind.
Old February 26th, 2009, 10:49 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
It is extremely easy to push the vehicle side to side without the panhard rod.
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
ST rear load space matt in SW? Seriesman Defender Technical Discussions 6 November 2nd, 2004 12:44 AM
Pre load of diff bearings. andersoriginal Defender Technical Discussions 9 October 10th, 2003 04:08 PM
