Panel lights - Defender Source
Old September 8th, 2014, 03:41 PM
atpick's Avatar
atpick
Andy
1990 110
Panel lights
Simple question that I'm sure someone on here will know. I just bought a 1990 110 and am wondering if the instrument panel lights are supposed to come on automatically when you turn the headlights on? I can't find a switch anywhere and they don't come on when I turn the headlights on. On my 84 110 I had to flip a separate switch to turn the instrument panel lights on. Sorry to insult everyone's intelligence, thanks for reading.
Cheers,
Andy
Old September 8th, 2014, 03:43 PM
They shouldn't have a separate switch. They should come on with the parking light being selected.
Old September 8th, 2014, 03:49 PM
atpick's Avatar
atpick
Andy
1990 110
Ok great...guess I have my first project....
Old September 8th, 2014, 03:52 PM
Nothing like undoing somebody else's electrical "fix". Good luck, I wish was there to lend a hand and drink some London Pride with you.
Old September 8th, 2014, 03:59 PM
atpick's Avatar
atpick
Andy
1990 110
Thanks brotha, nothing a few beers can't fix I suppose....anybody know off hand which fuse relates to the instrument panel lights? I would look on the back of the fuse panel but that is missing.....
Old September 8th, 2014, 04:04 PM
on early trucks and I forget when they stopped this practice- there is a rocker switch on the dash with three positions. One position turns on the dome light, one position is everything off, third position turns on dash lights.
Old September 8th, 2014, 04:13 PM
atpick's Avatar
atpick
Andy
1990 110
Yeah, that's how it was on my 84. This truck however has only two switches down there, the hazards and the rear fog light
Old September 8th, 2014, 04:21 PM
fuse ?
Old September 9th, 2014, 02:06 AM
atpick's Avatar
atpick
Andy
1990 110
fuse ?
Yeah, that's what I'm thinking, gonna check it today. Unfortunately the fuse cover panel is missing and they usually have the location of the fuses labeled on the back...I'll just look for a busted one I suppose
Old September 9th, 2014, 07:43 AM
the rover shop
shayne young
One of The rocker switches next to the steering column control the dash lights..in the upper position the dash lights come on automatically with the lights.. In the centre position they are off.. And in the lower position it turns the interior light on.. If your missing the rocker switch that will note than likely be your problem..it should be as simple as bridging a wire at the switch connector temporarily..
Edit.. Forget this... I see Doug has already answered this... Unless it has interior light door switches it should still have this switch for the lights and interior lights..
Twist-lock bulb mount for warning panel lights? rankar Defender Technical Discussions 8 February 8th, 2015 07:53 PM
gauge and lights panel diagram help please! kevincdoyle Defender Technical Discussions 2 April 13th, 2014 02:31 PM
93/94 Headlamp panel vs Series 3 headlamp panel Macker Defender Technical Discussions 3 July 27th, 2011 02:44 AM
'94 tail lights on newer style rear body panel? Green Blood Defender Technical Discussions 5 March 29th, 2009 11:20 PM
Dim Instrument Panel Lights gearco Defender Technical Discussions 2 June 20th, 2004 11:29 PM
