Panel disassembly question (how do I do it)? - Defender Source
Old November 21st, 2016, 12:41 PM
bnoonan
Brice
1988 RHD 90
Hello all,
As I'm presently working out some issues that make my 88 Defender immobile, I'm considering pulling the body apart to take in for a respray (even when I get it running, it is winter and the heat does not work). I've got an empty garage and the desire....it is the skill and know-how I'm not so sure of.
I'm just wondering what it takes to get all painted parts off and back together. Anyone know of any good pages or threads that detail this process and what it takes?
Old November 21st, 2016, 05:02 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Landroverworkshopdvd | Workshop Manual | Fitting Instructions
Google landroverworkshop and look through the video results. There's lots of them on youtube.
Your biggest hurdle is dealing with rust, corrosion and seized fasteners.
Old November 21st, 2016, 09:01 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is easy. As mentioned you will find some bolts that will not cooperate. The big problem is where to stop fixing stuff.
Land Rover 110
Old November 21st, 2016, 11:30 PM
bnoonan
Brice
1988 RHD 90
Yes, I imagine this is the case Mike. But I'm glad to have a resource like Scott recommended. Looks helpful and I'm hopeful my providing panels to the body shop will enable me to cut paint costs and allow me to figure out all of the issues and simple fixes (and what large fixes are down the road).
Old November 22nd, 2016, 03:59 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
If you are seriously delving into this, you can source new cappings, panels and such. YRM in the UK (not the ULC/ULR version) has good bits, as do others.
Pulling the cappings and other rear tub pieces gives tou the ability to get at the corrosion underneath, and replace what is too far gone.
Also opportunity to use butyl for sealing joints, 3M seam seal or equal, new foam seals for floor, tunnel, windscreen, roof, new window seals. These trucks can actually get fairly water resistant.
Sound deaden the crap put of it! You can actually have a conversation, or hear the radio.
Good luck.
KGH - “Stinky LR diesel” Defender Snob
Old November 22nd, 2016, 01:45 PM
bnoonan
Brice
1988 RHD 90
Hear the radio!? Really? Hah, I look forward to that.
Old November 22nd, 2016, 02:43 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
If your cappings aren't too badly rusted, it's worth having them sand blasted, then galvanized. You would be surprised how something REALLY nasty looking and rusty cleans up with sandblasting.
Less expensive than new galv. and you know they are the correct fit, you know they'll last a long time!
assembly
Light Panel question rwavers Defender Technical Discussions 7 May 31st, 2015 02:19 PM
bulkhead repair panel question jayz Defender Technical Discussions 2 October 15th, 2012 04:36 PM
SW Door panel disassembly - help needed rlynch356 Defender Technical Discussions 2 June 13th, 2009 07:33 PM
SW Interior Door Panel Question mgrgpg Defender Technical Discussions 8 July 24th, 2007 11:00 AM
fuse panel question Overlander Defender Technical Discussions 3 January 2nd, 2007 01:34 PM
» Defender Registry
G4
CamelTM
Awesome-o
Jdc0430
Add your Defender
