Painting Trim? - Defender Source
Old September 20th, 2010, 08:57 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Painting Trim?
Does anyone have experience painting the interior trim? I know it will never match the black door cards so figured I could do them body colour. If you have, did it stick well? Durability?
------ Follow up post added September 20th, 2010 10:23 PM ------
Would using a fabric covering make more sense?
Old September 21st, 2010, 06:30 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
plastic dye
Hi Andrew, i've had good results from using a plastic dye i bought off ebay it has restored the colour of my faded center console, also used it to touch up the other black plastic dash parts rubber arch flares & wing covers.
it seems to be quite resistant to marks as i did the console first and have been pulling it in and out of the truck during the build with no marks or scratches on the finish.
a sod to get splashes off your face though.!
http://cgi.ebay.co.uk/Plasticare-Tri...-/260655185091
before and after pics below
regards
Name:	CIMG1423 (Large).JPG
ID:	31299   Click image for larger version
Old September 21st, 2010, 01:47 PM
Naplm00
Matthew
When I would do the plastic trim on my e30 stuff I only used 2 products.
First was SEM trim paint
http://www.vinylprosem.com/page/1287002
You can find this stuff at better auto body supply shops and online. It produces a hard chip resistant (but not chip proof) finish. I used this to black out some old chrome bits. The key is in the prep, a smooth surface that is non plastic needs to be scuffed with a red scotchbrite, plastic and plastic textured items should have adhesion promoter first then the SEM trim paint.
http://www.amazon.com/Plastic-Intl-1.../dp/B000LNOOEO
I also used Plasti-dip spary on coating, this offerd a slightly textured, extremely durable rubber type coating. I used this on chairbacks, coil springs and external plastic trim that could be chipped by rocks. This shit is amazing, minimal prep is needed for any surface and it will stick like glue. When you want to remove it just rub like a sonofbitch with a rubber pad and it will ball up and come off clean like an eraser.
Ive seen people use the plasti-dip to paint whole wheels and dashboards, crazy stuff.
EDIT: http://dodgeforum.com/forum/3rd-gen-...-complete.html
Old September 21st, 2010, 01:53 PM
ajh
Andrew J. Hutton
The bits I'm worried about are the ones that go around the rear windows, down the B-pillars, etc. The original ones are a grey but the new interior door panels are black. I have some plasti-dip spray here but I've mostly used it as a metal isolation coating so far and ideally I'd like to keep the original texture on the panels so a dye seems like a sane first choice. Just need to find some closer than the UK.
Old September 21st, 2010, 02:21 PM
Naplm00
Matthew
you can pick upbasic Vinyl dye at most auto outlets like pepboys,autozone,kragen ect. IT comes in about 10 colors
Old September 21st, 2010, 02:22 PM
ajh
Andrew J. Hutton
Thanks, I'll give it a try, though the kind of places we have around here are pretty sad.
Old September 21st, 2010, 02:41 PM
Naplm00
Matthew
possibly?
http://www.amazon.com/s/ref=nb_sb_no...ords=vinyl+dye
Old September 21st, 2010, 02:42 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
the SEM paint mentioned above is fantastic for painting plastics. If I had to do my door cards or rear trim, it's what I'd use. I did my wheel arches with it and it bonds incredibly well and isn't effected by the sun. I did a bumper skin on a car years ago and it lasted forever. Has good flexibilty and toughness. A truly professional product. I used the 'Trim Black'
It is pricey though at $11 a can around here. Generally, automotive paint supply places will have it.
Old September 21st, 2010, 08:15 PM
ajh
Andrew J. Hutton
I found some good comments on the Duplicolor Vinyl and Fabric Dye and managed to find some locally in flat-black so I'm giving that a try, so far other than being incredibly aromatic (which I suppose bodes well for how well it will bond) it seems to lay down a pretty nice finish after only 2 coats with no visible build, and only 9.99CAD/can.
paint
A few moron questions about interior trim panel removal. rustydefender Defender Technical Discussions 17 March 23rd, 2016 05:12 PM
Exmoor Trim seats loykd Misc. Chit-Chat 38 August 20th, 2005 05:15 AM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
Painting your Fiberglass Top boshea Misc. Chit-Chat 10 June 13th, 2004 09:41 AM
Painting prep kellymoe Defender Technical Discussions 2 February 9th, 2004 10:05 PM
» Defender Registry
LELOTRK
jefhuf
Rupert
REDrum
Add your Defender
