Painting or Powdercoating a Galvanized Chassis - Defender Source
Old May 11th, 2007, 01:53 PM
61rover's Avatar
61rover
John Crouse
I know lot's of folks like the look of the galvanized chassis, but I like the black. Are there any issues with painting or powdercoating a galvanized chassis?
Old May 11th, 2007, 02:16 PM
94SW,4.6HSE,93LWB,83 110
I know you can powdercoat over zinc/galvanizing but you would have to ask a powdercoating shop how well it sticks. The local shop I have been using just did a jeep frame and it looked great.
Old May 11th, 2007, 02:27 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I would paint mine if it's possible... I'd want to be able to touch it up easily when I scratch it.
Old May 11th, 2007, 02:35 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I won't ever powder coat another part that can come into contact with the ground. It just chips or scratches and then water gets under it and starts to bubble and rust. For less money you could galvanize it. I painted mine.
Old May 11th, 2007, 02:38 PM
I painted mine, and I totally regret it.
1) Even though I prepped it carefully, the paint doesnt adhere properly, and its coming off
2) The galv weathers and darkens so its not always bright zinc colored
3) I would still paint the rear crossmember, but now I wish I had the bling factor of the galv showing on the underside.
Old May 11th, 2007, 02:48 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I personally like the painted look with the corrosion resistance of galvanizing as well. However, it is a pretty involved process to paint galvanized items correctly. I was looking into it for a boat trailer long ago. Here are some interesting links that might get you started though...
http://www.corp.indgalv.com.au/technical/abrasive.htm
http://www.galvanizeit.org/publicati...blications.htm
http://www.finishing.com/faqs/galvnizg.html
http://www.galvanizeit.org/resources.../paintprep.pdf
http://www.duncangalvanizing.com/master_spec.html
~Scott T.
'95 D-90 ST - AA Yellow
Old May 11th, 2007, 02:49 PM
cellulararrest
Chris Snyder
Didn't Randy galvanize both the bulkheads on his truck build-ups? Maybe he can shed some light on painting over galvanizing.
paint
sounds nice low miles 97 with galvanized chassis evilfij The Flea Market 1 May 20th, 2009 12:21 AM
Galvanized Chassis Orderes Arrival Mid - End March 110/90/Series SafariHP The Vendors Loft 0 January 26th, 2009 03:07 PM
Series 2A conversion to new D90 body freeloader Series Technical Discussions 16 September 20th, 2005 10:30 PM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
painting galvanized stuff artm Defender Technical Discussions 5 June 29th, 2004 02:19 PM
