painting galvanized stuff - Defender Source
Old June 28th, 2004, 04:45 PM
artm
Arthur Maravelis
97 SW
Anyone have experience painting over hot dipped parts? Recommendations?
Old June 28th, 2004, 09:34 PM
Don't you need to etch it then use a special primer?
Old June 29th, 2004, 01:41 PM
artm
Arthur Maravelis
97 SW
Here's a bit of good info:
http://www.rust007.com/destroyerfaq.htm
This looks good as a primer.
Old June 29th, 2004, 01:48 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Yes you can paint over primer! All you need is primer that is made for that purpose. I sanded my parts after galv to smooth the coated surface. I will try to post pic's of the finshed product.
Peter
Old June 29th, 2004, 01:57 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Galvanized material, I have been repeatedly told, outgasses and if you use certain "sealed" paints (someone mentioned powder coat finishes), then the outgassing will bubble the surface. I have not checked out this information, but if I was to paint over galvanized material, I certainly would....FWIW
Old June 29th, 2004, 02:19 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I have had mine with no trouble for 5 years!
Peter
paint
Painting or Powdercoating a Galvanized Chassis 61rover Defender Technical Discussions 6 May 11th, 2007 02:49 PM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
Hard Top and Stuff ron For Sale - Parts 22 November 14th, 2004 06:35 PM
FS: Misc stuff: cubby/jack/tool roll NASD90 For Sale - Parts 1 October 19th, 2004 06:33 PM
Galvanized stock shock towers... dmarchand For Sale - Parts 1 May 22nd, 2004 04:28 PM
